Thread: Losing water at corners of intex ultraframe rectangular
    Sep 2013
    Dallas, TX
    25
    Hello. We have a 16x32 intex ultraframe rectangular. The liner drops a couple of inches at each of the 4 corners, and water is constantly splashing over them when kids in the pool. If anyone has any advise on how to block the corners off, I would really appreciate it. It's always wet around the pool, which is a problem since it's level. Has anyone seen how this can be blocked off somehow? All advise greatly appreciated. Thanks
    Intex 16X32 with Intex pump and SWG--nothing installed yet and will upgrade to larger pump and DE filter after full install completed.
    22,542
    Re: Losing water at corners of intex ultraframe rectangular
    Post a pic of a corner, but I'd look at taking some foam or thick vinyl and gluing it in the corners to help a little. You may be able to find some thick pool liner at a pool store or from an installer if you know any and use that.
    Jul 2015
    Auburn CA
    2
    Did anyone have a good solution? I just set up 12x24 and have similar concern.... would like to minimize water loss as much as possible. --Thanks
    Dahkodah's Avatar
    Jun 2016
    Freeport me
    11
    Had same issue this season. Here's my solution using a deep bin from ikea kids storage. Need two bins for 4 corners. Cut to shape of corner. Drill holes. I may have done over kill. And string up. Zip ties probably just as good. image.jpgimage.jpg
    Quote Originally Posted by Dahkodah View Post
    How did this hold up? Has anyone else found other solutions? Thanks so much!
