Thread: lots of rain....gotta love free water...but...
    Aug 2008
    Las Vegas, NV
    116
    Even though I drained water out yesterday to below the middle screw on the skimmer, this morning, the water level was back above the skimmer. Of course, I'll drain more off today, but what can this cause damage to my pump if it runs and the water level is covering the skimmer? I have it set to run about 4-5 hours during the night. I'm not sure where the water level was last night when the pump came on. What do you do when it's just pouring down rain all the time, for several days in a row? Should I just turn my pump off until the rain is over or drain some more water now and then more this evening, if needed before bed. I would hate to let it drain overnight without me watching it...If the rain stopped and I kept draining, it could drain out way too much.
    TIA
    Pam
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: lots of rain....gotta love free water...but...
    The only issue is that the skimmer won't be skimming the top of the water anymore. No reason not to run the pump.
    Aug 2008
    Las Vegas, NV
    116
    so, running the pump with too much water in the pool doesn't damage the pump, right?
    Of course running the pump with too little water would not be good and could burn the pump up, right?
    Pam
    Yes, you have it correct. Too much water isn't a significant problem. Too little water will eventually cause the pump to run dry, which will cause it to overheat, which will damage the pump if it goes on for more than a few minutes.
