Thread: Does Arm and Hammer and add Borates
    May 2015
    Miami, Fl
    47
    I ordered the borate test strips from tftestkits and test showed 15%. I want to add borax to my pool as recommended in other posts, 30-50. Does the baking soda add borax? If not, why did test show borates?
    Built March 2015 13000 gallon free form exposed aggregate with sheer descent, Jandy 2HP VSP, Jandy 1400 SWG with Aqualink PDA and AquaCal electrical heater. Pentair Clean and Clear filter 150SF. TF100 test kit. Pentair Kreepy Krualy Great White.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Does Arm and Hammer and add Borates
    My first question when folks want to add borates is why do they want to? I truly feel that most people should have a season or two under their belt before they add another dimension to their pool care.
    I will have to leave the test reading to Chem Geek to sort out.
    Support the site
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    I agree with Tim. The question is why.
    Borax is used to raise pH and can help stabilize it a bit. But if you dont have a pH problem, then there really isnt a reason to add it.
    If its a water chemistry thing, then post up some test results and we can have a look.
    If you want the "shine" to the water and the silky feel, well, I think those are subjective. I Borated my pool and really dont tell any difference between with and without. Again I agree with Tim about waiting to add another variable to the question. Once you have your water balanced for several months on end without any problems and start understanding the chemistry a bit, then thats when its time to experiment with borates.
    Divin Dave,
    Mar 2007
    San Rafael, CA USA
    12,082
    Try testing tap water to see what that looks like on the test strip. There are no borates in tap water. I suspect it's just variation between the test strip and the reference colors on the bottle. Baking Soda should not register as borates on the test strip.
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by chem geek View Post
    Thank you Richard. I said earlier I learn something every day, so I can go to bed now.....
    Support the site
