Thread: Pool return not working
    Pattylevcun's Avatar
    Jun 2015
    bayville, NJ
    2
    Cool Pool return not working
    Hi everyone,
    i'm new on here and happy that I've found this site. Our 18 x36 in-ground pool has finally filled up to the level we need it in order to run the pump (we had our vinyl liner replaced) 3 lbs of shock are in, but I noticed that one of the 4 returns is not pushing the water out like the others. When I cover the return with my hand for a second or two, the pressure gets better. Any idea as to what is going on?
    thank you
    PattyLevcun
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: Pool return not working
    You have very little flow but it will build pressure over time? That sounds like some sort of restriction in the plumbing - a chunk of plaster or a collapsed pipe. See if you can't unscrew the return jet and look inside. Maybe there's some plaster in a few inches you can poke loose with something.
    The other possibility is that the pipes are too small for the jets or the jets are too big for the pipe. If it's the farthest jet from the pump, what happens when some helpers stick their thumbs in two of the other returns? If the slug picks up speed, you just need to get smaller return eyeballs.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP!
    Apr 2010
    Central NJ
    227
    Do you have valve by your equipment for the returns? Could that be partially closed?
    23K gallon, IG, Vinyl, Hayward DE-3600 Filter, Raypak 406A Heater, Hayward 1.5HP SP2610X15 pump aka AO Smith UST1152, TF-100 Test Kit
    Jun 2015
    bayville, NJ
    2
    Thanks for your. Reply!
    It's actually the return closest to the pump. We closed another return off and the water flow was much stronger. After opening it again it's back to a slow flow. No pipes or jets had been replaced so I am guessing that's not the problem. I sure hope that there is not crack in the pipe.....
    any other suggestions?
    patty
    I double checked all the valves to make sure they are open all the way.
    PattyLevcun
