Thread: pool pilot low amps cell?
    Jun 2015
    jupiter/fl
    2
    Hi, I've had salt generated pools for quite a while and have had to replace the cells before. Currently I have a pool pilot digital nano. The warning light comes on and the readout displays warning low amps cell?. When I do a test the readings are salt 3200 temp 89 Degrees 36v .2 amps. Anyone know if this definitely need to replace the cell or could it be something else?
    Thanks
    22,553
    Re: pool pilot low amps cell?
    It's certainly a good indicator of a worn out cell. How old is the cell?
    Jun 2015
    jupiter/fl
    2
    Quote Originally Posted by Bama Rambler View Post
    It's about 2 years old. Would it have these readings if the plug is messed up?
    22,553
    It certainly could have if it's not making a good solid connection to the cell.
