Results 1 to 12 of 12
Thread: New pool pics and numbers
    FunFinder's Avatar
    May 2015
    Cajun country, Louisiana
    115
    Finally the pool is out of the box and up! Took a few days and many men to dig up cypress knees for a level pool pad. Here are some pics of the process and my chemistry numbers at the end:
    Pool was full on Monday and I added the salt. Ph was 8.5. Brought it down to 7.5 and added my sock of CYA. Here are today's numbers:
    Ph 7.5
    FC 4 (Intex SWG ran for 8 hours Tuesday and I had FC way to high, so haven't turned it on again yet)
    CC 0.5
    CYA 50 (just put it in Monday evening)
    CH 150
    TA- this I am not sure about. Is pink the same as red for the purpose of this test? The solution was still pink after 40 drops and I gave up.
    Thanks to everyone who has helped me get this far!
    Intex Ultra 9'x18' AG, 2800 Gph .75hp pump, 77# sand filter, Intex ECO SWG, Hayward wide mouth skimmer, KK Lil Shark vacuum, Intex magnetic light, TF-100 w/ SpeedStir
    38,267
    Re: New pool pics and numbers
    The TA should start green and change to pink/red.
    All test are done until the last drop does not cause any further color change and then do not count that last drop.
    Careful with the static on the TA test too as the instructions state, wipe the tip.
    FunFinder's Avatar
    May 2015
    115
    Ahhhh, I see...that helps! I probably missed that in the directions somewhere. Let me do the TA again, because I don't know when it changed to pink, as I was waiting for red. Thanks for the help!
    Oh, yea, I did wipe the tip too.
    FunFinder's Avatar
    May 2015
    115
    Ok, TA is 110.
    38,267
    Sounds like you are in pretty good shape
    FunFinder's Avatar
    May 2015
    115
    Do I need to lower the TA? I read to do that by aeration, but how would I accomplish that without a fountain? I don't have time to build something. Is there an easy, quick solution?
    Also, do I need to add more CYA or will the level come up more over the next few days? Everything that was in the sock dissolved. Sorry if these are stupid questions- I just don't want to get it wrong.
    38,267
    No there is no need to actively lower the TA.
    Also aeration does not lower TA, it just raises pH ... so then you can add acid to lower the pH and TA.
    What was the CYA target you used when you calculated how much CYA to add?
    FunFinder's Avatar
    May 2015
    115
    Thanks for the explanation. I *think* I put a goal of 70 for CYA.
    38,267
    Then I would wait a full week to verify the CYA level before adding more.
    FunFinder's Avatar
    May 2015
    115
    Thanks for your help Jason!
    Scuba_Steve's Avatar
    May 2015
    Pooler, GA
    311
    Just FYI, I have the same SWG. My pool is just over 6000g. I am at 5 hours per day of SWG time and still overshooting slightly.
    6425g Intex Ultraframe 18'x48" AG
    Stock 1500gph cartridge filter / Intex SWG CG-28669 with E.C.O.
    Install date: 5/26/2015
    TF-100
    Helpful Links
    FunFinder's Avatar
    May 2015
    115
    Quote Originally Posted by Scuba_Steve View Post
    Thanks, I'll keep that in mind. I did not put any bleach in and only used the SWG, set at 4 hours and pushed the boost button. That little SWG sure does it's job!
