Thread: Pool Pump Capacitor Replacement
    Hey guys - been a while since I've been on here. Tuesday evening, I noticed my pump wasn't on, so I manually shut off the timer, and I figured I would just start researching the problem on Wednesday. After reading a few posts on here and on youtube, the cause of my pump's failure seems to be the pump's capacitor. When it was on, it would hum slightly. It's a Pentair 1hp superflo pump, so it had a "doghouse" on the top of the motor to hold the capacitor. I cut the power, and attempted to spin the impeller from the strainer side, and it would spin freely both directions. So I took the old capacitor off IAW the youtube video, and tried to test it. All I have is a digital multi-meter, but supposedly, only analog and very special digital meters could be able to test it. My ohm reading was "infinite", being it displayed just a "1".
    I later researched that the capacitor terminals can become bowed outward when they go bad, which - on the old one - they definitely were. I went ahead and ordered one with the same specs as the old one off of amazon, just because I could next day it. My pool is starting to turn a bit cloudy, and with the weekend...if I need to order some other part, I need to do it soon so I can get it here ASAP. So my question is...for you guys that have done this, does this definitely sound like a capacitor problem? Or should I be looking somewhere else?
    Thanks!
    16,500 Gallon Rectangular Vinyl Pool; Aquarite SWCG T-15
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    Re: Pool Pump Capacitor Replacement
    It does sound like the start cap.
    I would get some bleach in the pool and stir it around with a brush/net to mix it as well as possible.
    Support the site
    Yep, sure nuff, new capacitor fixed it. Fitting was slightly different. Same diameter as the old one, but the new one was an inch longer. Had to modify the doghouse casing to get it to fit right, but it cranked right up. Thanks!
