Results 1 to 15 of 15
Thread: Full Test on Pool and Looks Pretty Good. What Adjustments Can I Make?
    Jun 2015
    North Hollywood, CA
    20
    Hi All,
    Received the Taylor K-2006 kit recently and ran a test on my pool to get a baseline of where things are at. Results are:
    FC 2 ppm
    CC 0
    pH7.8
    TA 110 ppm
    CH 280 ppm
    CyA 45
    FC seems to be on the low side with pH is on the high side while TA seems over my goal which I am simply basing off of TFP recommended levels for a plaster pool with bleach. These aren't necessarily in any condition where I need to do something immediate are they? Any advice on stabilizing the levels would be much appreciated!
    28,000gal IG plaster, Leslie's Crystal Clear II DE Fliter, Pentair 2HP 2 speed, Taylor K-2006
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Re: Full Test on Pool and Looks Pretty Good. What Adjustments Can I Make?
    you need more FC and quick! your minimum FC at that level (use CYA of 50, always round up) is 4ppm...right now you are in danger of algae starting. you should raise your FC to the target of 6. I would take it to 7 and see how long FC is lasting, but don't let it go below 4.
    how are you chlorinating?
    pH is a little high, but not crazy. take it down to a bit with MA. that will eat up some of your TA over time (lowering the pH). wouldn't worry about your TA too much unless you are getting a really quick rise in pH
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Jun 2014
    15,255
    You'll see my reply on your other thread. Hop on that FC ASAP.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Raise FC up to about 6. Lower pH to 7.2/7.3 TA will come down on its own. Wait 30 minutes between each chemoical addition.
    The recommended level for TA is 70-90+ Meaning, if you're below, you target something between 70 and 90 so you know how much baking soda to add. If you above, just plug in your current number as the target, it will tell you to add nothing, and you move along.
    Jun 2015
    North Hollywood, CA
    20
    Great advice. I added 130 oz of 12.5% liquid chlorine and 60 oz of muriatic acid this afternoon. I'll take another test in the morning and see what kind of changes that made.
    On another note: I noticed the pool has a layer of chalky residue that makes the floor look pretty discolored. I haven't brushed or vacuumed it just yet but it seems to come off by just rubbing it with my hand so I'm guessing it's some kind calcium build up. Would a simple nylon/stainless brush and vacuum job take care of it?
    Video for clicks
    Thanks!
    Richard320's Avatar
    Jan 2010
    19,071
    I'm not sure what that stuff is exactly, but I had a lot of it at one time. That's why brushing and vacuuming are important.
    A wall whale brush really helps.
    Jun 2015
    North Hollywood, CA
    20
    I'm starting to think that the previous pool cleaner never really brushed the pool at all now! I can see some spots where it looks like someone attempted to brush but never really finished the job. I'm feeling better and better about my decision to take care of this myself.
    So I've read about the Whale Tail brush before. Is it really that nice having the spoiler on there? Or is the brush itself just that good?
    Chemical balance looks much better this morning too.
    FC 7.5
    pH 7.5
    TA 100
    CH 290
    CyA 40
    Jun 2014
    15,255
    Just curious .. did you have a CC reading to post as well? How does your water look now?
    Richard320's Avatar
    Jan 2010
    19,071
    When you're doing the walls, it's a backsaver. You just push down. It pushes against the wall for you. It can develop some serious pressure. On max lift, it will bend a pole. Guess how I know. When you shove it across the floor and hit the end of the stroke, stop and watch the wave erupt on the far wall in a few seconds.
    wjr75's Avatar
    Jun 2013
    IL
    836
    I have the wall whale brush regular size and love it. I hate brushing to start with and don't do it as often as I probably should.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Jun 2015
    North Hollywood, CA
    20
    The whale sounds like serious business. I actually ended up picking up something similar to it. It still has a spoiler on it (albeit much smaller). I'm hoping it will do a similar job to the whale.
    Texas Splash - The water color and clarity look really good. I did forget to add the CC numbers on my last post. Here they are for this morning...
    FC 6.0
    CC 0
    pH 7.5
    TA 100
    CH 260
    CyA 40
    Jun 2015
    North Hollywood, CA
    20
    So after a day of swimming with some friends over the calcium buildup from the walls have turned made the water cloudy and raised the CH up to 280. The visibility can't be more than 7 feet or so. I ran the pool filter for a good majority of the evening hoping some of the calcium would filter out of the water but no luck. Any ideas on how I can maintain the water clarity as I scrub down these walls that have been neglected for so long?
    The other chemicals were off this morning as well:
    FC 2.5
    CC 0
    pH 7.4
    TA 110
    CH 280
    CyA 35
    FC and pH dropped a bit so I added some chlorine and soda ash to raise those levels back within range.
    Jun 2015
    North Hollywood, CA
    20
    Any help with the above question?
    Today's #'s are:
    FC 6
    CC 0
    pH 7.6
    TA 100
    CH 270
    CyA 35
    Jun 2015
    North Hollywood, CA
    20
    Bump for my Q
    Richard320's Avatar
    Jan 2010
    19,071
    You'll probably want to raise the CYA a bit to deal with the sun. 50 is a reasonable target. When you do that, your minimum FC level goes up, but daily chlorine use should come down a little.
    pH is fine. It's between 7.2 and 7.8
    TA is no problem. It's in the 70-90+ range
    You can't do much about CH, that comes out of the tap, and it's okay.
    All you can do with the cloudiness if it's coming off the walls is brush and be patient and let the filter get it. Anything you can do to improve circulation helps. I like to get maximum flow on the main drain while I'm brushing in hopes it will end up getting whisked away when I brush it that direction.
