Thread: Jet Making Gurgling Sound With A Lot of Pressure
    I have a gunite inground pool, about 21,000 gallons of water, and a Hayward DE filter. One of the jets is somehow connected to a small pipe near where an old big pool slide used to be. The small pipe is exposed by about a couple of inches above the cement. The pipe causes the jet to blow out at a high pressure and makes a gurgling sound. This does not affect the pump pressure, but I'd like to fix it. Here is what it looks like.
    Mar 2015
    Cantonment, FL (Pensacola Area)
    380
    Re: Jet Making Gurgling Sound With A Lot of Pressure
    Have you tried capping that off, even if not glued?
    Scott
    15,000 Gallons vinyl in-ground screen enclosed, Hayward Eco-star SP3400VSP, Hayward Aqua Logic PL-Plus, Hayward T-15 Salt Cell, Hayward S244T Sand Filter, Polaris 380 with booster pump, Hayward heat pump HP50HA. K-2006 kit.
    38,524
    As you said, that small pipe likely once fed the slide with water. Having the pipe open should not really increase the water flow strength, but it could allow the pool return to suck in air like a spa jet. Just put a cap on it and see if that fixes your concern.
    I'll give it a shot. Thanks for the advice!
