Results 1 to 17 of 17
Thread: Pool Equipment - Surround
    tackettaj's Avatar
    May 2015
    Mooresville, NC
    47
    We just finished with getting our pool built but due to HOA regulations and space constraints we had to place our pool equipment in the back yard behind the pool. I've been searching for some nice ways to enclose the equipment but haven't found anything that I would be happy with. Looking to get some ideas. The picture shows location of the equipment.
    -25,000 gal. freeform gunite, smooth quartz finish w/ spa
    -2 hp Jandy Pro Series Stealth; Jandy Pro Series Cartridge Filter (CV340)
    -Jandy Pro Series AquaPure Chlorinator; Jandy Pro Series JXi Heater
    -Zodiac MX8 cleaner; Taylor K-2005 DPD Complete Chlorine Kit
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,537
    Re: Pool Equipment - Surround
    I would think about building a 2 sided trellis and plant or put in pots some jasmine or other sweet smelling climbing plant.
    Or you could build a 2 sided "privacy fence" around it and paint a cute mural on it.
    Just make sure you leave plenty of room all around the equipment in case you need to remove it or work on it.
    Kim
    Jun 2014
    15,165
    The pics is kind of far away. Any chance you could post another pic a bit closer so we can see everything you need to store? Gorgeous pool by the way.
    tackettaj's Avatar
    May 2015
    Mooresville, NC
    47
    Sorry for the long delay. I've been traveling and didn't have access to my laptop.
    This pic is when it was getting installed but I think it give you an idea of just how much needs to be surrounded.
    Jul 2012
    Tallahassee, FL
    30,537
    Weed barrier with big rocks all around held in by brick or such. This is to keep it clean and weed free.
    Lattice or a privacy fence . I would not paint it as that is just another thing to take care of. I would do as I said above--plant climbing vines to pretty it up and hide it. Some thing that smells good.
    I would only do it on the two side to allow room to work with the equipment if needed.
    Kim
    tackettaj's Avatar
    May 2015
    Mooresville, NC
    47
    Great ideas...thank you!
    Jun 2010
    Massachusetts
    96
    I just ordered this screen to hide my propane tank that will go just past the edge of the woods. Not sure if it would work for your space but it comes in different colors. Woven Resin Privacy Screen
    Building 20x40 free-form pool; pebble sheen, caretaker in floor, swg, intelliflo pump, heater. Sundance 800 spa happily in use. More to come!
    Mar 2015
    El Cajon, CA
    31
    I would dig a footing with rebar coming up about 6 feet. Then would bend it to give a shape of a rock. Cover the rebar with screed using tie wire to attach it to rebar. Then get the fiber glass fill to mix with sand and cement to cover the screed. while it is still setting up form with trash bags, berlap sack, and hand tools to look like a big rock. Finish with 4 or 5 colors of paint applied with a pump sprayer. Take your time search you tube and it look like a rock and will not look out of place like a fence.
    IG, pebble tech, 25K gallons, grotto, SPA that spills into pool, water slide, two other water falls. Equipment Pentair, filter FNS + 60, pool pump 1.5HP single speed wisperflo, spa 3 HP single speed wisperflo, grotto/ slide 3HP single speed wisperflo, waterfall 2HP single speed wisperflo, minimax NT 400K btu, Hayward XL pool vac, SWG IC60, compool 3800 automation, built 2007.
    tackettaj's Avatar
    May 2015
    Mooresville, NC
    47
    Quote Originally Posted by bacr619 View Post
    That sounds impressive!
    Quote Originally Posted by superwy View Post
    Sent from my SM-G900V using Tapatalk
    That would for sure be a quick inexpensive way to do it.
    Mar 2015
    El Cajon, CA
    31
    I will take a pick of mine so you can see the front and back. The cement and steel would probably be $400.00. your labor $1000.00 finished product priceless.
    Golderdog's Avatar
    Feb 2015
    DFW
    61
    Laugh if you want.....however - one word - Pinterest. Join and do a search. Lots of great ideas you would would not normally think think of. Also lots of pool landscaping ideas. I look at it, and see some clever and fun ideas, however not knowing your tastes, makes it harder. Are you traditional, low maintenance, a DYI type, etc? Might help to see back of house and other landscaping in area to blend the concept in.
    Roman Style 20+ Year Remodel 4'-10.5'. 25K Gallon - Hayward SWG conversion. SWG. Blue Granite PebbleSheen w/Shells. Ash Nero Trim Tile. Remodel of steps, added bench seating and small sundeck. Maytronics Dolphin M4 Robot Cleaner.
    PoolESQ's Avatar
    Dec 2007
    Albuquerque, NM
    191
    Only thing I'd add is if you go for some fence type enclosure, put some foam sound insulating board to absorb the sounds of the equipment.
    Replastered 2015: Sunstone Quartz Midnight Blue 16x32 rectangular gunite with in-pool spa....18,000 gallons. Autopilot Total Control System with SWG and acid pump. Pentair Clean & Clear 420. Auto cover. TF-100.
    Clayswen's Avatar
    Jul 2012
    Dean, Texas
    134
    Here's some overkill on hiding things, but sure does work...ha
    102 Perimeter Freeform Pool, Rock Waterfall, Jandy Deck Jets, Depth 3'6" - 6', Stonescapes Aqua Blue Mini Pebble, Inpool Table, Rock Salt Decking, Jandy 2.0 Epump, Jandy 580 Cartridge Filter, Polaris 280 with booster pump, Jandy Power Center w/ PDA, Stenner Pump
    A country boy's pool build...Dean, Texas
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    Given the location, I would do it with landscaping in front of a black lattice wall/fence. Maybe start with 8g podocarpus planted 2' on centers as a screen.
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
    Mar 2015
    El Cajon, CA
    31
    The equipment surround has a 12 x 12 footing with 1/2 rebar every 18" vertical and 18" horizontal. I would bend the rebar to get curves in it. I used premix concrete on the wall and applied it with a shovel. Basically I just lobed it on and formed with trowels, plastic bags, burlap and brushes. You will need to allow it set up a bit before working it. Just remember there is no set texture or shape of a rock. The biggest thing that gives a fake rock the real look is the painting. I painted a base coat with flat (all paint flat) tan with pump sprayer and brush very thick. The rest was browns, gray, black, and other mixtures of the same colors. All of the rocks you see in these photos are hand made.
    SuzfromTexas's Avatar
    Apr 2015
    Houston, Texas
    3,217
    All of those rocks/boulders look amazing!! I love how you did the rock screen for the pool equipment. Did you do all the work on your pool and grotto, etc? Do you do this as a hobby or your work? Fabulous!!
    Suz.
    Suz~Cypress area~ 2015 pool build. 23K gallons. IG swcg system. 35'x18'; 573sf; 104' perim; depth 4'-7'. Bubblers, sheer descents, 7' spa. Jandy: color LEDs; 2HP 2sp pump; 1HP 2sp pump; spa pump; 580 cartridge; 400K BTU; Dolphin M500; PS8; Inline chlorinator not used; Aqua Pure 1400. Blue Granite Sheen. Travertine deck. Lightstreams Peacock Blue TF-100, K-1766, SpeedStir
    Mar 2015
    El Cajon, CA
    31
    I made most of the rocks and the equipment screen. I hired some one to do the entire grotto. The build was back in 2006 or 2007 owner builder. I work in the construction field and have lots of contacts. The thing that makes these look so good is the painting. Thank you for the kind words.
