Page 1 of 2 12 LastLast
Results 1 to 20 of 31
Thread: Algae again... Clears - comes back - reappers - Advise?
    Cant stand this pool's Avatar
    Jun 2015
    Hauppauge, NY
    13
    Hi all - Lets get you some background here. I've had this pool for 31 years (seems like forever). New filter 3 years ago - new pump this year. New liner 6 years ago. Kids used to use it all the time - I never use it. Anyways.. It was used all the time when the kids were growing up - now since they are out of the house, I have to open it because it is all of my back yard. Wife uses it occasionally. Last few years I battle with algae. Not so much green water - it grows on the walls and seems to be a dust of it on the bottom. I can see it clearly - so the water usually isnt bad. I brush the walls - case of shock after dusk, run the filter and by the next day it looks great. Trouble is, three days later it starts to form. A trip to the pool store will leave me looking to remortgage the house. After some research, I wound at this site and the help seems to be genuine. I check the chlorine (usual drops test kit) and it is good. I never used stabilizer... Which after a little reading - I'm guessing I should be. I do backwash on a regular basis, especially after a bought with algae. I do disassemble the filter and wash it out once during the summer. Does the fact that there is what I would refer to as 'inactive water" effect this? (What I mean by that is, nobody walking on the bottom, churning up the water) I know of so many people in my area with this issue - even brand new pools with plenty of activity. Aside from a few dump truck loads of dirt - I hope I can get this under control once and for all this year. I read a few ways to do the stabilizer - skimmer basket / sock filled with it ~ my trouble is, I will need a lot. I have close to 50,000 gallons of water to treat - If I need 10 or more pounds, how will it all dissolve? I do appreciate any help offered - many thanks!
    In ground "L" . Size - 20X40 with a 16X20 L. 9ft deep end with diving board - All other 4 FT - Hayward DE filter - Hayward 1.5 HP Super Pump - Hayward CL-200 Chlorinator. 50,000 Gallons of misery...
    Skitch's Avatar
    May 2015
    Athens, Georgia
    112
    Re: Algae again... Clears - comes back - reappers - Advise?
    Do yourself a huge favor and get a test kit. Either the Taylor K-2006 or the TF-100.
    You can have that pool crystal clear in a matter of weeks, if not days.
    18,400 gallon 28' round above ground pool sand filter 2013 K-2006 2014 new Hayward pump 2018
    My pool turned green the second year, K-2006 saved me, Trouble Free Pool set me free
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    You won't know if you need stabilizer until you get a proper test kit. See here: Pool School - Test Kits Compared
    There are many sources of stabilizer (aka CYA or cyanuric acid). You can buy it as a pure chemical. However, most people who don't think they've ever used it have been using it for years. Trichlor pucks that MANY pool owners use add chlorine AND cyanuric acid to the pool with each tablet. Dichlor powdered shock adds chlorine AND cyanuric acid as well, with a higher CYA/chlorine ratio, so it adds it even faster than trichlor. You may already have enough (or more than enough) CYA/stabilizer in your pool.
    Step 1 to take control is get a good test kit.
    Step 2 is to read what you can in Pool School to understand the methods and the science behind them. ABCs of Pool Water Chemistry is a great place to start.
    Step 3 is asking questions about what you've read and posting test results from your test kit. We'll help you from there.
    Welcome to TFP!
    Isolated Spa - 345 Gallons
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    First, Welcome to TFP!
    While there certainly could be circation issues, your trouble is rooted in lack of Chlorine problems. This I promise you. Being at 50k gallons, I'll be honest and tell you that going Salt Water Chlorine should be considered. We use liquid Chlorine here mostly, but that is a big pool. If you can get bigger stronger quantities where you are it would be easier. Also, you may have flexibilty to use some form of powdered Chlorine to supplement. To find out, a full set of numbers from a good kit would be needed to make that determination. And having one is essential to gaining control and eliminating these issues. All the help and knowledge is here to get this done BTW. We are all about knowledge, understanding, and testing to gain full control and a trouble free pool.
    Essential Links:
    Quote Originally Posted by Cant stand this pool View Post
    I brush the walls - case of shock after dusk...
    Welcome to the forum!
    When you say you add a case of shock, what type of shock? If it is powdered dichlor, that will be adding stabilizer to your pool. If you've been doing that a lot, your stabilizer (CYA) level could actually be very high, reducing the effectiveness of your chlorine, and contributing to your algae problems.
    You'll need a good test kit to test your CYA level. Pool store tests are often woefully inaccurate, and the CYA test is the one they get the most wrong. For an accurate CYA reading, you need to do the test yourself using one of the Recommended Test Kits.
    25000-gallon semi-public IG concrete/plaster pool, Triton II sand filter
    750-gallon semi-public IG concrete/plaster spa, cartridge filter
    Volunteer pool caretaker for my condominium complex
    Jun 2015
    Hauppauge, NY
    13
    Quote Originally Posted by TomBorg View Post
    I use liquid shock. I ordered the K-2006 test kit on-line. As soon as I receive it I will do a test and share the results. A chemist I'm not.. I do agree with the pool stores in testing water - every store has different results. I cant afford to use their advice with the amount of water I have - I'll go broke. Wish I had found this site a long time ago - Thanks for all the input and advice. I'll hold off on the dirt for now.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Post up numbers when you recieve your kit and we will get you going
    There are five chemical levels that every pool owner needs to keep track of:
    •FC - Free Chlorine - A sanitizer which keeps your pool water safe and free of germs. Chlorine must be constantly replenished. (level depends on CYA)
    •PH - Acidity/Alkalinity - Needs to be kept in balance to prevent irritation and protect the pool equipment. (7.5 to 7.8)
    •TA - Total Alkalinity - Appropriate levels help keep the PH in balance. High levels can cause PH to rise. (60 to 120, sometimes higher)
    •CH - Calcium Hardness - Appropriate levels help prevent plaster damage. High levels can cause calcium scaling. (220 to 350, vinyl lower)
    •CYA - Cyanuric Acid - Protects chlorine from sunlight and determines the required FC level. (outdoors 30 to 50, SWG 70 to 80, indoors 0 to 20)
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,672
    You are on the right track. We can and will help you with the pool and tests. There are videos of each test that are easy to follow.
    When you say "liquid shock" do you mean bleach or chlorine? Just curious.
    Kim
    Jun 2015
    Hauppauge, NY
    13
    Jun 2015
    Hauppauge, NY
    13
    Kim, I use a product called "Super Shock". Dark yellow in color - I get it at a local pool supply. Again - Thanks for all the help!
    Jun 2015
    Hauppauge, NY
    13
    Sorry - After looking at my post I still didnt tell you if it was powder or liquid - I have always used liquid shock.
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    Welcome to TFP! So glad you found us before you called in the dump trucks! Reminds me of another recent thread posted by a user named "JustFillItIn". His pool was an amazing nuclear green color.
    He has since changed his user name to "DontFillItIn" and is now the proud owner of a sparkling clear Trouble Free Pool!
    When I saw your user name I got excited because I know we can help you to figure this out and take control and soon you won't be hating your pool anymore.
    Although you have never specifically added stabilizer/conditioner alone, as others have already mentioned, most of the solid/powder forms of chlorine already have the stabilizer (CYA - Cyanuric Acid) as an added ingredient. I see your signature says you have a Chlorinator. If that is the type of chlorinator that uses chlorine pucks you will already have CYA in the pool.
    We'll soon know just how much when you get your test kit in.
    Definitely keep reading around the site while you're waiting for your test kit. Specifically the articles in Pool School.
    This is a good one to start with if you haven't already read it. ---> Pool School - ABCs of Pool Water Chemistry
    Any questions about what you've read can be asked right here and there will be a bunch of people ready to answer or explain.
    Welcome again and congratulations on taking control of your pool! After so many years doing it the pool store way I think you're really gonna like it here.
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    Jul 2012
    Tallahassee, FL
    30,672
    Your test results are going to be interesting to see.
    Let us know when your test kit comes in.
    Kim
    Jun 2015
    Hauppauge, NY
    13
    Thanks! Yes - I use the pucks. Slow dissolve 3''. I buy them on line from either Dohenys or In the Swim. I will get the results up as soon as my kit hits the mail box. I'm actually eager to learn about the readings. I am really looking forward to enjoying this pool rather than dreading it. Until it arrives - I'll be studying in the "Pool School" library. On a positive note, the pool looked good this morning.. Have a great weekend all!
    Here's another question - How do you keep ducks out of your pool? I have two that have taken up residency. Not all day, but they seem to enjoy a 6 AM and evening swim... I let the dog out - she barks at them, they could care less.
    Feb 2014
    Central Minnesota
    5,080
    Ducks that already like your pool area might be tough since they already feel comfortable there. I've heard some folks have success with flags or long reflective streamers around the pool. Use the search function as well and I bet you'll get some ideas.
    Jun 2014
    15,298
    Ducks huh? Might be time to get a couple Labrador Retrievers. They love water and ducks. Welcome to TFP and enjoy your weekend as well.
    Jul 2012
    Tallahassee, FL
    30,672
    We used a net and caught the one that came to stay. There was duck poop all over the outside and inside the pool and all over the deck We relocated him to a pond down the road. He has not been back.
    Kim
    Jun 2015
    Hauppauge, NY
    13
    They are making a mess of the bricks... cute fellas, but annoying. Test kit is scheduled to arrive today!!! I get to plat scientist when I get home !!!
    Jul 2012
    Tallahassee, FL
    30,672
    I see a selfie with you looking all sciencey and stuff! LOL
    Kim
  20. Back To Top    #20
    Jun 2015
    Hauppauge, NY
    13
    with my goggles and white coat.. Ha! is there a video on the basics of how to use the kit? I saw a few on youtube.. they go a little quick for me.
