Thread: Would this be a good way to test CYA
    Jul 2013
    Northeast
    128
    Would setting the tube on a white surface (white concrete or a printer paper) with my back to the sun be the best way to test it?
    I can't figure out if I have 30 or not. When I hold the tube at the waist level the water is shaking a bit and it looks like I have 30. If I have it sitting on the concrete it's more like 25-27
    I know CYA test is +- 10ppm, but would sitting bottle on the ground be the more accurate testing?
    23k in-ground plaster. Cartridge filter Hayward 450 or 550. Hayward 2ph pump.
    liquid chlorine, tablets occasionally when out of liquid and cya allows it. ph down.
    stabilizer (Had no cya last two openings, but never before that)
    no other chemicals used in years
    TF100.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Would this be a good way to test CYA
    Holding it at your waist is best. Test needs indirect light from all directions to be accurate. Setting it down eliminates some of that light. Your CYA is 30. I'd consider bumping it up another 10 ppm to be more efficient, cost effective with your chlorine usage.
    Isolated Spa - 345 Gallons
    38,248
    When in doubt ... buy the 50ppm standard CYA solution
    TFTestkits.net
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    And, it isn't accuarate eniugh to discern a few PPM. Call it 30 I agree, and adjust accordingly.
    Essential Links:
