Results 1 to 10 of 10
Thread: pool store testing question
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    ok, I know what you are thinking, haha.
    I have a TF-100 but, I want to check the salt level. is the pool store testing for salt at all reliable? I know the taylor kit is +/- 200ppm and the strips are more...but in reality, the salt doesn't need to be that accurate anyway but I want to get a ballpark. seems like a waste to drop $40 on the taylor kit for something I will use once or twice a year.
    Thoughts?
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: pool store testing question
    I'd go with the cheap option for home testing. TFTestkits.net They're good enough for what you need.
    Isolated Spa - 345 Gallons
    38,473
    All the tests are +/-400ppm I think ... I prefer having the Taylor kit myself (which is not $40) so I know the testing in consistent and I can see trends.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Strips just for Salt are OK, but I'm with Blizzle on this. If it's worth knowing the cost is not a waste at all.
    It's 26.50 at Tftestkits, so not sure where you saw it was
    $40.
    Essential Links:
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    ok, thanks guys. I saw it $40 on amazon I think. thru TFT kits, looks like $30 after shipping. thanks!
    Dan
    Donldson's Avatar
    NW Ohio
    2,916
    Even the Aquacheck strips are relatively accurate at $14. They work by capillary action so are not bound to the same color match crud-shoot as other test strips.
    Not to take any sales away from TFT, but you can usually get the same ones locally if the price is right.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    I got the strips and found them for $9 shipped. plus or minus 400 should be fine
    Dan
    38,473
    Hope they are not old or near expired
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    will find out I guess.
    Dan
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    well...those strips say my salt is at 600ppm...lol. so, back for refund and getting they taylor test
    Dan
