Thread: Bleach question
    Jun 2015
    lagrange ohio
    17
    Bleach question
    My bottle of clorox reads this:
    So which % number do I plug into the pool calculator to get my desired add?
    The yield chlorine which is 7.85
    Or the sodium hypochorite which is 8.25?
    Thanks!
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Bleach question
    8.25 is the number to use.
    Even that number is an estimate as bleach is always produced within a range of acceptable %. It might be over 9% when produced by the manufacturer and as low as a few percent if it's been on the shelf a long time.
    Isolated Spa - 345 Gallons
    Jun 2015
    lagrange ohio
    17
    Re: Bleach question
    Thank you so much!!!
