Results 1 to 7 of 7
Thread: Kids are WEARING ME OUT about swimming!
    Jun 2015
    madisonville, tx
    35
    40K gal pool
    CYA is 42
    PH is 7.4
    FC is around 14
    Pool was green and cloudy when I started the process, but is clearing up. I can actually see the bottom of the pool now on the shallow end and it is moving towards a blue tint as opposed to green, but is still overall cloudy. Hayward sand filter running 24/7. CYA was at 0 4 days ago. Added a total of 12 lbs of stabilizer over a two day period and it's holding steady now. Prior to that, the FC would have zeroed out by now. Brought the FC to 16 2 days ago and haven't added any since. It's still reading higher than my Taylor test kit shows so I'm estimating it at between 14 to 16. Kids are wanting to swim and communicating that through their loudspeaker (aka "The Wife"). Is there an issue with people in the pool with the chlorine levels so high? Should I hold my ground and make them wait or are they ok to get in. Tough to play hardball on this when it's 97 degrees out.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Kids are WEARING ME OUT about swimming!
    Where are you getting your test results? A recommended test kit or pool store?
    If those are results from a recommended test kit, it's safe to swim in that pool with an FC of up to 16/17 ppm. Provided you can see that bottom of the pool clearly for safety reasons. You may see swim suits fading more quickly or it be a bit harder on hair but it's safe to swim. Have them rinse off before and after going in. Before to save your FC, after to rinse off suits/hair well.
    Isolated Spa - 345 Gallons
    Jun 2015
    madisonville, tx
    35
    I bought the test kit at a pool store. Made by Taylor, relabeled for the pool store, but tests for CYA, CH, TA, etc... I have another test kit ordered to verify results. My kids thank you for the quick response
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Welcome to TFP!
    It is safe to swim when:
    PH is between 7.2 and 7.8
    Chlorine level is above the minimum level for your CYA
    Chlorine level is below shock level for your CYA
    You can see the bottom of the pool.
    Pool School - Chlorine / CYA Chart
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to TFP!
    Make me the bad guy and tell the kids they need to wait. I sincerely suggest a full and complete SLAM on this pool before you let them swim in it. You can begin that once the proper kit arrives. It really sounds like you need to do this.
    Essential Links:
    Jan 2014
    Buckeye AZ
    807
    when the wife asks you if there is too much chlorine in the pool for the kids, and your response has to be "I guess it's alright" because you don't have a test yet that reads that range....well let me know what response you get
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by BuckeyeChris View Post
    A better one would be: "Hon, I don't know. Before we risk our kids well being, why don't we get a proper kit and find out?"
    Essential Links:
