Results 1 to 7 of 7
Thread: Chloramines
    Jul 2010
    Apopka, Fl
    31
    Chloramines
    My FC was at 4pmm CC 1.0 so I shocked with the powdered stuff, 1 bag FC went up to 8.0 CC .05...so I added another bag. Now FC 12.0 CC 0.0 I turned my SWG to 0 and it's been 4 days and FC 10.0 CC 0.0 but I smell Chlorine in the air in early morning when pump is not running, and I smell it on my body after a swim. I thought shocking was supposed to get rid of the chloramines which is the smell, right? Should I continue to let the FC level drop on it's own?
    thanks
    Inground 15x30 oval, plaster, 11250 gallons(?) with pool cage...jandy 100sq ft cartridge filter... SWG...Taylor K2006 Test Kit
    Located Apopka, Fl...Orlando area!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Chloramines
    What else is going on, and how does the water look?
    We don't "shock" here in the typical sense/terminology, we do it under a very tightly controlled procedure called SLAM.
    Essential Links:
    JoyfulNoise's Avatar
    May 2015
    13,247
    Re: Chloramines
    What's you CYA level? Whether or not you are truly at shock levels of chlorine depends on your CYA level.
    If your water is having problems, you should do an OCLT to see how much chlorine you are losing overnight. Then, if warranted, do a SLAM.
    Matt
    Jul 2010
    Apopka, Fl
    31
    Re: Chloramines
    Thanks for the replies. Pool is sparkling clear. Here are my numbers today:
    FC-7.0
    CC-0.0
    PH-7.6
    ALK-80
    CYA-75
    SALT-3000
    CH-310
    BORATE-50
    I NO LONGER SMELL THE CHLORIMINES OR CHLORINE SWG STILL AT 0% Seems like it's taking a long time to drop the FC. Should I be at about 6 on the FC?
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Re: Chloramines
    Quote Originally Posted by sixtz4me View Post
    FC-7.0
    CC-0.0
    PH-7.6
    ALK-80
    CYA-75
    SALT-3000
    CH-310
    BORATE-50
    taking a long time to drop FC is a great thing, don't complain about that
    based on CYA of 80 (round up), your target FC is 6. nothing wrong with keeping it at 7 like you have. I would fire up the SWCG and start fine tuning it keep your FC stable where you have it. will give you some wiggle room
    BTW, which test are you using to get these values?
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Jul 2010
    Apopka, Fl
    31
    Re: Chloramines
    Dan, thanks for the reply... I'm using Taylor K2006
    Scuba_Steve's Avatar
    May 2015
    Pooler, GA
    311
    Re: Chloramines
    You probably want to add that to your signature. Reason being is you will get asked what kit your using in every thread you make if it is not in there.
    6425g Intex Ultraframe 18'x48" AG
    Stock 1500gph cartridge filter / Intex SWG CG-28669 with E.C.O.
    Install date: 5/26/2015
    TF-100
    Helpful Links
