Thread: Valve Question
    Valve Question
    My current setup has 3 3way valves, operating my suction cleaner, main drain, and skimmer. They are old, hard to turn, and I am pretty sure leaking air into my system. I want to replace them, but I am having a hard time convincing myself that they are even needed. Someone please tell me why to use these expensive complex valves, instead of 3 individual inline ball valves? They would seem to give me better control of what water flows where, and are WAY cheaper. So can someone tell me why I shouldn't use plain old ball valves?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Valve Question
    Without seeing your setup, I'll hazard a guess. One reason might be to ensure that you can't accidentally close the wrong combination of valves leading to a dry pump or a pump going against a closed line.
    Many pool valves are rebuildable, and some need to be lubricated periodically for easy operation and sealing. If you post a picture and/or a diagram of your system, I'm sure somebody can advise you.
    John
