Results 1 to 8 of 8
Thread: No Juice on Intex Krystal Clear System
    Hello
    Just got the pool up and running, plug in my SWG and I am getting no power. No lights on unit, and no light on GF Transformer unit by plug.
    Is it possible its a fuse issue or transformer (I think that's what its called)--(Its by plug and trips when unplugged).
    Thanks for any insight, this is only the 3rd season of use.
    Just upgraded from Intex 15x48 to Pro Series 22x54
    2500gph Intex sand filter
    Intex Krystal Clear Saltwater System
    Located in Boston, MA
    22,553
    Re: No Juice on Intex Krystal Clear System
    If you're talking about the GFI plug strip, it could be bad.
    Can you test and reset it once you plug it in?
    Are you sure that the receptacle that you're plugging it into has power?
    Hi Bama, I get no lights at all on the GFI strip when test and reset are pressed.
    Tried different outlets. Nothing? Is the GFI part replaceable?
    22,553
    Some models have a plug in gfci and some models have a molded on gfci. The plug in ones are replaceable, but the molded on ones aren't without cutting the old one off and replacing it with a plug in one. That's really a job for an electrician. Plus, even if you replace it there's no guarantee that the unit itself isn't bad.
    Thanks, it looks like there is a plate on the bottom of the GFI unit with 4 screws, I wonder if there is a fuse in there?
    22,553
    I don't know if there's a fuse in there or not.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,557
    I have the CS8110 model, and there is no fuse in that one. Water leaked into mine and ruined it so that it would not reset. I removed it altogether and replaced it with a regular plug. The entire circuit is already on a GFCI in the house, so I didn't see any need for two of them in series.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Thanks guys, replacement plug is $17 at Home Depot. I hope that solves the issue.
