Thread: how to remove stains from vinyl?
    Jun 2015
    Holon
    4
    hello all.
    i emptied my pool 2 years ego and stupidly enough i folded the vinyl and left it outside in the winter rains and summer sun. now there are brown stains that wont scrub out. i tried putting bleach on a sponge and scrub but the stains couldn't care less. any suggestions?
    thank you.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: how to remove stains from vinyl?
    Welcome to the forum!
    You might try a dilute solution of Muriatic acid on the stains to see if that helps, but I'm not sure what to suggest beyond that. Sorry I don't have a better answer.
    Essential Links:
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,643
    Magic eraser? Just use care as it can be quite abrasive.
    Kim
    Jun 2015
    Holon
    4
    the Magic eraser sponge did nothing to it. also tried bleach gel and let it work for 10 minutes, nothing. not sure what Muriatic is and where can i buy it (not on line it will take forever).
    i included a photo, maybe someone can identefy this monster.
    tnx again for all the help.
