Results 1 to 20 of 20
Thread: New to pool maintenance
    Jun 2015
    Northwest Indiana
    12
    Hi there,
    I found you site while "google searching" the Nature 2 system. I was sold a bunch of garbage at the Great Escape in my area. Thank God, I came on here before I hooked it up. It will get returned tomorrow. I also ordered the TF-100 test kit, I dont have any test number yet.
    We bought a house with an existing 4 year old 21' AG pool. It had been "professionally winterized' by their pool guy. When I peeked under the cover it was crystal clear. The problem came when I drained the cover. I got most of the water out but not enough. When I finish pulling it off alot of the decomposed leaves leaked out the side. I jumped into the pool to save it but it was too late. lol A stream of leave diarrhea swirled around the pool.
    Now, Im gathering as much info as I can from this site. As of right now most of the big leave particles are gone. Ive been skimming them and running the pump. I had to add about 5-7" of well water to bring up the height. I dumped 4 1lb packets of the MAxBlue shock in so far. Now, Im holding off until I can get some real numbers to adjust.
    Opened 6/9/15 added 4 1lb Maxblue powders
    Water condition 6/11/15
    Cloudy blue can barely see the bottom
    test kit on order
    Thanks in advance
    21' above ground round, Splapool pump 72730, cartridge filter, 70167 inline chlorinator.
    TF-100 is on the way
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: New to pool maintenance
    Welcome to TFP!
    on ordering the TF-100.
    Your doing almost everything right. The only reason I say "almost" is because of this statement:
    Quote Originally Posted by scsbronco
    Those "shock" products can contain other chemicals that can have a deleterious impact on your pool. I would switch to plain unscented liquid bleach for chlorine - add about 1/2 a bottle per day until your kit arrives.
    TFP is about adding only what's needed to manage your pool. Here are some resources that give you an overview of our methods:
    1. ABC's of Pool Water Chemistry
    2. Chlorine CYA Chart
    3. Recommended Pool Chemicals
    4. Recommended Levels
    5. Pool Math
    When your kit arrives, test and post the results and we will go from there.
    Jun 2015
    Northwest Indiana
    12
    Bo thank you for the reply,
    The Maxblue shock was before finding this site lol. I posted that so, its all out there for everyone to see. I will pick up some bleach in the morning.
    I assume I should keep the pump running for now.
    Thank you very much
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,476
    Hello! You will be so glad you found us! We will get your pool clear and make it sparkle!
    You have already made a huge step with getting the test kit on the way. I can't wait to see your test results.
    For right now go price shopping to find your best bleach price. It might be at Walmart, Sams, ACE Hardware, pool store, etc. Make sure it is fresh and check the % when you price it out.
    Do you have any pucks in the chlorinator? If so go ahead and take it out. You can save it for when you go out of town or such.
    Kim
    Jun 2015
    Northwest Indiana
    12
    I took back the Fusion 2 today. BOY, was the guy at the pool store ******.
    "what wrong with it?"
    Me "nothing, I just don't want a bunch of unnecessary chemicals and metals in my pool"
    "copper and silver clean and sanitize you pol they are natural elements"
    Me "I don't care Ill take care of my pool myself"
    "we usually don't let people return chemicals"
    Me "guess what you are today!"
    My test kit is coming monday!!!!
    Jul 2012
    Tallahassee, FL
    30,476
    Nice job! So sorry ps guy he found TFP! LOL
    Kim
    Jun 2015
    Northwest Indiana
    12
    tf-100 test kit came today confused by the results
    chl- orange color
    pH 6.8 bright yellow
    FC = 41
    CC = 70 drops stayed clear no result may need to run test again
    tc- ?
    TA = 70 yellow
    CYA = 100
    i will be testing again in a few hours
    Jul 2012
    Tallahassee, FL
    30,476
    For right now only use the drop kit for the chlorine testing.
    If your FC is really 41 your PH test will not work. Do not bother testing PH with a FC 10 or over.
    With your CYA at 100 it could be higher as that is as high as it goes. You need to drain some water from your pool. Sorry.
    Here is a link to Pool Math. It will tell you how much to drain.
    http://www.troublefreepool.com/calc.html
    Let me know if you need any help using it.
    Kim
    Jun 2015
    Northwest Indiana
    12
    I figured that. Pool math said 60%. Will I have more problems filling it back up with well water?
    Jul 2012
    Tallahassee, FL
    30,476
    Have you ever had your well water tested for metals? Iron can be a big one for wells. If you have not had it test I would do so before doing anything. Some pool stores can test for it. It is the one test they kind of get right-------it does or does not have iron or copper.
    Kim
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Quote Originally Posted by scsbronco View Post
    Iron can be a problem with well water. You probably already know if it's a problem from stains inside the toilet tank and so on. It's not the end of the world. Check out these before and after pictures from a homemade Iron filter.
    This is the thread Just got Taylor-2006 Test Kit. Want to verify what I should add.
    Another great picture
    A Tale of Two Filters... and Ugly, Rusty Water.
    And there's also the worry of overtaxing the well and drawing sediment in.
    Jun 2015
    Northwest Indiana
    12
    We moved into the house 2 months ago. I have literally been going nonstop. I only sleep a 3-6 hours a day. I know the iron is high I have a filter for the house. Ill decide tonight what im going to do. I cant babysit the pool I work 12hrs. So, Ill have to get the chemistry figured out soon. Then, I can pass it off on the wife for SLAM.
    Jun 2015
    Northwest Indiana
    12
    Tomorrow i think ill start by draining 1'4" out then refill.
    Jun 2015
    Northwest Indiana
    12
    I drained Half the pool filling it back up now.
    Jul 2012
    Tallahassee, FL
    30,476
    Good start!
    Kim
    Jun 2015
    Northwest Indiana
    12
    I filled the pool back up. It has a green tint to it but its still clear. I added 1 gal of bleach. Its been raining nonstop here. I haven't been able to test. I will try in the morning.
    Richard320's Avatar
    Jan 2010
    18,995
    Green is okay. Rusty orange or coffee is even better. That means the Iron has precipitated so vacuuming it up or filtering it out will work. A brief backwash and it's gone. Try the paper towels.
    Jun 2015
    Northwest Indiana
    12
    I'm still at 90-100 CYA after emptying half the pool
    Orange
    6.8 ph
    Fc 41
    Cc clear no cc
    Ta 300
    Cya 90-100
    Jul 2012
    Tallahassee, FL
    30,476
    awwwwwwwwwww so it was higher than we thought.
    Drain some more please. You really need it down to 30 to SLAM. SOrry
    Kim
  20. Back To Top    #20
    Jun 2015
    Northwest Indiana
    12
    I have to talk it over with my wife if this is worth it. May just put it for sale. I've already put approximately 7k gal through the well.
