Thread: Best pump under $500
    Apr 2014
    Central Tx
    61
    So I think my 20+ year old Sta-Rite Dura-Glas II finally bit the dust. It was leaking pretty bad so I took it apart and replaced every seal and bearing, and now the **** thing won't even turn over. I don't know how old it actually is, but the part number is from a pre-1998 model, so needless to say, I think it's time to move on to something new. The catch is, I'm in the military and I know I'll be moving in less than 2 years so I don't want to break the bank. I'm just looking for something cheap and effective that will get the job done. I want to stick to a single or 2-speed pump just for simplicity. Right now I just have a manual switch and timer and I'd like to stick to that. Any suggestions for a relatively similar plug-n-play pump that will get me by? My current setup is in my sig.
    23,000 gal, in-ground, plaster with 24" sand filter, 1.5" piping.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Best pump under $500
    Give the size of your pool, a 1 HP 2 speed would probably work well for you, assuming you have 230V to the pump and no water features that you need to power. Although a 1.5 HP may be easier to find, and likely cheaper to buy. As to best place to buy I would suggest trying ebay, there are often pumps for sale at good prices, often old stock, distressed merchandise, or just people trying to liquidate inventory or sometimes no name specials. Just make sure you buy one for a inground pool, as above ground pool pumps often will not dry prime.
    Here are a few that may interest you
    auction for a returned pump Pentair 012530 WhisperFlo High Performance Energy Efficient Two Speed Full Rated | eBay
    Discontinued Hayward older pump double check the specs to make sure it is inground has has a filter basket
    New Hayward 1HP Power Flo Dual Speed Motor SP1720 | eBay
    New Pentair inground pump
    New Pentair Pool Pump 1 HP 230 V 43200 Gal 2 Speed Motor FPT20510 | eBay
    Hayward Maxflo II (popular pump)
    Hayward SP2710X152 Max Flo II 1 1 2 HP Standard Efficient Dual Speed Pump | eBay
    Jandy 2 speed flopro same pump I have, mostly like it but it can be a knuckle buster and o-ring needs frequent re-lubrication
    Jandy FHPM1 5 2 Pool Pump Flopro Medium Head 1 1 2HP Up Rated Dual Speed | eBay
    Apr 2014
    Central Tx
    61
    Thanks for the reply. I do have 220V available and no water feature. I'd like to stick with something new if I can just to buy me a bit of time with a warranty. The last thing I want to happen is for this thing to go out again.
    I saw a 1.5 hp in ground in Home Depot for $398. Won't last 20 yrs heck probubly not 5 but should for a few at least
    Flo tech I believe it was
    Using Tapatalk
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    For your situation, since you will be moving in less than two years, I would go with a 1/2 hp one speed pump. If you were staying there longer, I would recommend a 1 hp two speed pump. I would get the Pentair SuperFlo 1/2 HP Pump 340036 for $299.95 shipped.
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
