Results 1 to 11 of 11
Thread: Splashless Clorox
    Jun 2015
    Piscataway nj
    3
    Splashless Clorox
    I made the mistake of adding the splash-less clorox to my 22000 gal in ground pool. Its been 3 days and i still see foam on the surface. Should I shock with the regular clorox, or wait till the foam is gone? How long does it usually take for the foam to disappear? Ive never used the splash-less before, and didn't realize it wasn't the regular stuff. I dumped about 8 gallons in the pool. Thanks in advance for any advice.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Don't buy "Splash-less" Chlorox
    Welcome to TFP!
    Sorry to hear about this mistake. Just scoop off the foam from the surface. That's the fastest way to remove it and the rest will eventually dissipate. SLAMing won't help very much since chlorine doesn't react much with soap. Your pool will probably be mostly cleared up in a few more days, especially if you remove surface foam.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Splashless Clorox
    There is not much you can really do for this other than give it time, scoop away, and perhaps try one of the absorbant products like a scum ball or Zorb-o in the skimmer
    Jun 2015
    Piscataway nj
    3
    Thanks for the reply, the foam isnt thick enough to scoop. When I tried to scoop, it just seems to flow through the net back into the water. I was thinking of maybe filling the pool till it over flows and get rid of it that way. Thoughts on that please?
    Mar 2007
    San Rafael, CA USA
    12,082
    It's an idea that might work, but the oil-absorbant pads would likely work as well. Depends on whether you can afford to waste the water to overflow since it's probably a lot of water unless you have a rather small pool. It will dissipate so by the time you do all of this it may be nearly gone. Again, up to you since it isn't causing any harm.
    Jul 2014
    Sacramento, CA
    241
    What about using a pool noodle to push the foam into a small area, then a snow shovel or other solid scoop to lift it out?
    21000gal IG plaster, Sacramento CA area (late 1950s/early 60s)
    Filter: Cartridge, Pentair CCP420 (2014)
    Main pump: Pentair IntelliFlo VS (2015)
    Boost pump: 3/4hp (2011), Polaris 280 cleaner (unknown age)
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    crazzy idea, not sure if it would work or react the same way a spa does, but for the spa we use foam away... like this Amazon.com : Leisure Time HQ Spa Foam Down, 32 oz Bottle : Hot Tub Chemicals : Patio, Lawn Garden
    I think walmart has something like this... Again I am not sure it would work the same way, maybe try a small patch of foam and see if it does anything..
    Jun 2015
    Piscataway nj
    3
    Thanks for all the feedback You guys rock!!!. I like the snow shovel idea. (adaptive engineering), Ill check Walmart to see if they carry that product (Spa foam down) Ill also look for the oil absorbent pads as well. I noticed the foam has subsided quite a bit after I turn off the pump. Ill wait until tomorrow, and see what it looks like, and then Clean out the filters. Lesson learned about reading the labels of the bleach I buy. The labeling looks the same as the regular bleach.
    AquaBoy's Avatar
    May 2016
    Savannah, GA
    41
    Quote Originally Posted by chem geek View Post
    I know this is digging up an old thread, but I just made this mistake as I see from even older threads that this OP and I have not been the only ones. Should have known when I checked halfway through and couldn't find the 8.25% label listed anywhere. Anyway, I know it does not seem to be a problem to the pool itself, and this may qualify as a not-so-bright question, but is it safe to swim?
    23,000 gallon IG vinyl pool, Sand Filter Hayward Vari-Flo XL Valve Model
    Jul 2013
    Fletcher, OK
    3,353
    it is safe you may notice some bubbles but it's fine...
    AquaBoy's Avatar
    May 2016
    Savannah, GA
    41
    Quote Originally Posted by cowboycasey View Post
    Thank you, just wanted to double check before tossing kids in there!
