Thread: Poolmath vs Chlorine/CYA FC Recommendation
    May 2015
    River Falls, WI
    124
    My non-SWG vinyl pool has CYA at 50ppm. Poolmath says my FC range is 4 - 8. The CYA/Chlorine chart says 4 - 6.
    Why arenít they the same? Does it matter which target is used??
    ~19k Gal, IG Vinyl, Hayward SP2607X10 1hp pump, Hayward S200 Sand Filter, built in Ď70ís, has 8í deep end with diving board, 1 skimmer, 1 return, 1 low hole, Polaris booster pump PB4-60, old Polaris robot not sure model, Rheem P-M266A-EN-C 266,000 BTU heater, solar cover, Taylor K-2006 test kit, Speedstir
    38,260
    Re: Poolmath vs Chlorine/CYA FC Recommendation
    The target is arbitrary, the key is always staying above the minimum.
