Thread: Water temp question
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Water temp question
    Hey all,
    I have a very old heater that has a 3rd party digital thermostat built into it to control the temps better for the attached spa. Sort of like an aftermarket thermostat
    The probe for the thermostat is in a return side pipe right before the water flows into the heater.
    Its after the water flows through the basket, multiport, and is filtered.
    This works very well, but the temp of this device is consistently showing about 1.5-2 degrees cooler than the pool thermometer is saying.
    My question is... If I move this probe closer to the suction valve. Maybe before the water even goes through the pump basket. Can I possibly get a more accurate result? In other words, is it possible the water is cooling down a bit during the filtration process? Thanks a million!!
    18x38 Inground Liner (25k gal) Paver surround, multi-speed pump, DE Filter, Raised spill over spa, TF-100
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Water temp question
    What makes you think the pool thermometer is correct? We had the same issue when I installed our Solartouch, it read a couple of degrees lower than our $5 pool thermometer drove my wife crazy which drove me crazy. I threw away the pool thermometer and life has been good ever since.
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    I think you are correct. I have 2 of those cheapo thermometers. Turns out one of them is exactly the same temp as the probe thermostat and the other is about 3 degrees off.
    Then when I heat the spa, the accurate one shows about 4 degrees hotter than the probe thermostat. So Im thinking these things are basically just garbage. Ill trust the thermostat and look for a better thermometer.
    Thanks
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Or thermometers....
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    This is really funny
    The only reason it makes an actual difference to me is because the difference between 102 degrees in the spa and 106 degrees, is one is a comfortable, relaxing night. The other is being cooked like a lobster
    So I have to find something accurate.
    Or thermometers....
