Thread: question about pool lighting?
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    902
    I was thinking about getting a light that fits into the return jet of the pool...any ideas on what is the best item to get? Is there any performance issues that I need to worry about putting a light that also has a return flow in it into my AGP? Do some work better than others? Anything to avoid? I really like the idea of doing this I like night time swimming.
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: question about pool lighting?
    The Aqualuminator is the most common one I see. Putting a light in the return limits what you can do with the return. You no longer have a standard 1-1/2" female thread there to put in an APG or even a regular winter plug, and you don't have the benefit of a directional eyeball return.
    Feb 2008
    Northwest Indiana
    902
    Quote Originally Posted by spishex
    Any suggestions on something else...I really like the idea of a light in the pool, but do not want to cut a new hole if at all possible.
    Beave
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    You could go with The Nightlighter. It hangs over the edge, so that eliminates any hassles with cutting or changing your return, but you will have something hanging on the side of the pool.
    I've seen this style of light used on an I/G and it was great. They placed it under the diving board so it never got in the way.
    Do a search for the "Bouy".
    I've read good reviews.
    20x40 24,000 gal IG plaster/CircuPool RJ45 SWG/2 skimmer/2sp 2.5hp Jandy Stealth/340sq ft cart filter/600sqftHeliocol Solar Panels/6ft semi circlr tanning ledge/25ft deep end bench/5ft sheer descent/2 lion head water features/1300sqft travertine paver/2 Colorlogic lights/Hayward Navigator/3step 2ft raised bond beam
