Results 1 to 8 of 8
Thread: What causes burning/stinging eyes
    Apr 2015
    South Central PA
    297
    It seems like all of the pools that I've been in are different regarding the burning/stinging of eyes. What causes this? Is it just a result of proper chlorination/pH, too much chlorine of too low pH? Even though I check FC/CC every day and pH every day or so, knowing how the water should feel helps verify testing.
    20000 gallon vinyl liner in ground pool
    16' X 34' rectangular diving pool
    Hayward Pro Grid DE Filter
    Hayward 1 hp Super Pump
    TF-100 Test Kit Stenner 45MPHP10
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,013
    Re: What causes burning/stinging eyes
    Use the search box for Stinging Eyes.
    This particular post from chem geek is also interesting Burning/Stinging eyes
    Apr 2015
    South Central PA
    297
    Thanks...I did search, but I kept seeing salt mentioned and I assumed it was SWG people. Am I reading the link correctly that any pool, not just SWG, could benefit from adding salt?
    Richard320's Avatar
    Jan 2010
    19,013
    Quote Originally Posted by 440dodge440 View Post
    It was quite the fashion here a year or two ago to add salt for feel. I never jumped on that band wagon nor added borates simply because I'm constantly draining to reduce CH buildup.
    Apr 2015
    South Central PA
    297
    Thanks again...it's not really too big of an issue now, but I'll keep the salt in mind is it is needed
    Richard320's Avatar
    Jan 2010
    19,013
    Don't forget that chlorine adds salt to a pool. It'll slowly build up.
    Mar 2007
    San Rafael, CA USA
    12,082
    The paper in the link that Richard gave to a post I wrote describes how chloramines can also irritate the eyes. Nevertheless, even with no chloramines, if you just keep your eyes under water even with no chlorine or chloramines, they will sting unless the water is salty. Basically there's more salt in your eyes than in the water so water flows into your eyes creating pressure that makes your eyes bloodshot and sting.
    Apr 2015
    South Central PA
    297
    My first thought was chlorine was too high, but I'm reading it can be the chloramines like mentioned. My wife just noticed it stung a bit, so I'm hoping it's the lack of salt -I didn't know chlorine added salt, so that should help. I do a daily FAS/DPD test showing less than .5 ppm CC, so hopefully I can rule out the chloramides. Thanks for the help!!!
