Results 1 to 17 of 17
Thread: What glue to use with solar panels and PVC
    Oct 2014
    Bay Area, California
    146
    To make a long story short, I bought some solar panels off Craigslist and I need 4 barb fittings that are no longer available. It is not a universal part it's a special threaded fitting with o-ring made by the panel company.
    I figured out that 1 1/4" pvc fits perfectly, just like it would press into an elbow etc. so as my last resort I am going to glue sections of PVC into the panel. Is standard PVC glue ok to use? I don't know what type of plastic the panels are, but I remember reading that some types of plastic(maybe abs?) don't react well with the glue.
    Approx 15,000 gallon gunite pool, fiberglass finish. Hayward SP2302VSP, compools solar controller, 6 4x10 "Sealed Air" brand solar panels, Clean and Clear 520 cartridge filter
    38,508
    Re: What glue to use with solar panels and PVC
    I do not think any glue will work with what most panels are made of.
    DaneCE's Avatar
    Jul 2011
    VA
    279
    Types of PVC Cement
    By Roger Golden eHow Contributor
    PVC cement is a chemical solvent. It literally fuses the pieces of pipe together. There are three primary types of plastic piping used, but all are generally referred to as PVC pipe. Each type of PVC requires a different cement. PVC (Polyvinyl Chloride) and CPVC (Chlorinated Polyvinyl Chloride) are very similar, while ABS (Acrylonitrile Butadiene Styrene) has a different chemical composition.
    PVC Cement
    • PVC cement is specially formulated for schedules 40 and 80 PVC pipe. When it is applied, the pipe will visibly soften and then solidify as the cement sets to form a joint that is stronger than the surrounding pipe and fittings. Be careful to avoid skin contact because PVC cement can cause chemical burns on sensitive skin. This pipe and cement are generally used in DWV (drain, waste and vent) applications, not potable water transport.
    CPVC Cement
    • CPVC cement can bond pipe joints without creating hazardous vapors when fusing PVC pipe designed for potable water transport. Apply the cement with the included dauber, uniformly lining the connecting surfaces. Avoid CPVC cements that have thickened as this is an indication that the catalyzing agents have partially evaporated, reducing its bonding capability.
    ABS Cement
    • ABS cement is chemically engineered to react with the chemical structure of the pipe. It is used with ABS piping, but is unsuitable for use with CPVC or PVC pipes. ABS piping is recommended for DWV applications and is available in two types: Solid Wall and Cellular Core. It is important to use the correct type of cement in all applications to prevent the pipe from weakening and unable to carry the desired pressure.
    Transitional Cement
    • A special type of cement called a transitional cement can be used when multiple types of PVC pipe, such as ABS and PVC, are joined. This variety of cement fuses the chemical structures of the pipes together without causing extreme chemicals reactions or creating harmful fumes.
    Oct 2014
    146
    Do you know what type of plastic they are made of?
    As last resort number 2 at least epoxy should work. Though I want to be sure I come up with a pretty good solution as failure could be disastrous.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Can you find a standard recycling logo on the panels, if so the number inside the logo should tell you the class of plastic that it is made from, often it will be polypropelene or EPDM polypropelene (which is a ruberized polypropelene compound). Is there any way you could use rubber / silicone hoses and hose clamps on the panel as is?
    p.s. maybe if you post photos of the connectors we could help with ideas better
    Oct 2014
    146
    No recycling logo
    I need 4 more of these:
    Pvc is a tight fit
    Oct 2014
    146
    as of right now this seems like my best bet: Loctite 0.85 fl. oz. Plastic Epoxy-1360788 - The Home Depot
    Isaac-1's Avatar
    SW Louisiana
    6,711
    My thought is you would need something more flexible than epoxy since the PVC and the black plastic will expand at different rates when heated. Maybe something more like RTV silicone
    Oct 2014
    146
    Quote Originally Posted by Isaac-1 View Post
    Yeah now I'm planning on using CPVC. I could look up the thermal expansion, I feel they probably wouldn't be that different though. And the strength of epoxy is like 3000psi. Would be nice if I could just find the fittings.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Sure the epoxy may be 3000 psi, but would prefer the glue to fail instead of the PVC or collector tubing due to thermal expansion.
    Oct 2014
    146
    Ok so I figured out a way to do it where the fit between the fitting and panel don't need to hold the fitting in. So is there anything I need to worry about when choosing a silicone to seal it? is there something special that is resistant to pool chemicals or should anything be fine?
    Jun 2014
    Roseville, CA
    343
    There are lot of kinds of silicon sealants. Dow 795 is a good choice:
    DOW CORNING 795 SILICONE BUILDING SEALANT
    This is used as an outdoor sealant, metal to glass (in my world), and is tough and weather proof. As I recall, it is a neutral cure to avoid etching that can lead to sealant failure.
    You probably won't get it a Home Depot. Go to a large commercial glass shop. They will probably have it or a proper substitute. It's not cheap.
    Also, I've had really good luck with Gorilla Glue. My Hayward navigator had a "impeller" that split in two. I tried everything. Gorilla glue did the trick.
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
    Apr 2013
    Argyle, TX
    77
    That part looks like the Nylon radiator end tanks on modern cars.
    Good luck with the repair
    This company sells adhesive for most any situation Reltek > Product Selection Guide > Material Substrate
    Available at Fastenal or GRAINGER
    21' NEW YORKER II 54" DEEP AGP Private Label MORADA RTR WILBAR Aluminum wall
    Hard Bottom and 1/4" Floor Pad 1/8" Wall Foam Well Water Perma 2500 Unibead liner King Technology Pool Chlorine Feeder HAYWARD Diver Dave cleaner
    Waterway 22″ Sand Filter 1.5 HP Center Discharge Pump Single speed Wide Mouth skimmer
    Jun 2014
    Roseville, CA
    343
    I wonder if you can get a female threaded collar with a "to pvc pipe" end?
    My Ideal Specs:
    Jun 2015
    Fremont/CA
    2
    Hi Nick,
    We're you able to make something work?
    I have these exact panels and the threads are failing for some panels
    -tumachar
    Quote Originally Posted by Nickmpower View Post
    No recycling logo
    Pvc is a tight fit
    May 2018
    Quebec
    5
    I would use plastic jb-weld i user to repaire my Heather pump heat exchanger.
    Jun 2015
    Fremont/CA
    2
    I ordered new O-ring. Will try with that and Teflon tape first. If that does not work, will try JB-Weld Waterweld. I got a stick just in case. Will report back next week.
