Thread: No Chlorine in my pool
    Jun 2015
    Staten Island, NY
    5
    I can't seem to keep chlorine in my pool. The water has the slight cloudy look. Here are my detail. Please help. Thanks
    14' x 24' inground vinyl pool
    Approx 10,000 gallons
    Jandy Cartridge filter
    Aquarite T9 salt chlorinator set to 40%
    Colorq pro 7 test kit
    FC 0.21
    TC 0.44
    PH 7.4
    ALK 51
    CH 115
    CYA 60
    pool store tested phosphates as good.
    Shocked already 3 times in 2 weeks with about 2 bags each time.
    What am I doing wrong?
    Thanks.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: No Chlorine in my pool
    The reason you are having difficulty keeping chlorine in the pool is that there is something organic in the pool that is consuming it. The cloudy look is an indicator of that and it could be nascent algae that hasn't gone into full bloom yet.
    This is the typical "shock" treatment which is completely ineffective. We have a process called the SLAM that you will need to familiarize yourself with and perform in order to clear up your pool.
    So, here's what I recommend: Start by getting yourself one of the Recommended Test Kits. I use the TF-100 because it's the best value and they have a freshness guarantee. You can order it here: TFTestkits.net. They ship fast - you should have it in your hands in 2-3 days with normal shipping. One of the tests it contains is the all-important FAS-DPD test which you will need for the SLAM.
    Second: While you are waiting for the kit, I would check out these short articles to give you an overview of managing a pool using our methods:
    1. ABC's of Pool Water Chemistry
    2. Chlorine CYA Chart - This concept is critical to understand as it governs the amount of chlorine you need according to your CYA levels.
    3. Recommended Pool Chemicals
    4. Recommended Levels
    5. Pool Math
    Finally, do not worry about phosphates. Chlorine and chlorine alone in the proper dose will kill and prevent algae no matter the level of phosphates.
    Jun 2015
    Staten Island, NY
    5
    Thank you for the reply. I already have the Colorq pro 7 test kit. Is this not good enough? Also to get my chlorine up to 28 shock value, about how much chlorine would I need? Would 15 gallons of liquid chlorine be enough?
    30,403
    The ColorQ has a bad habit of not being very reliable....particularly on CYA and CH.
    Use http://www.troublefreepool.com/calc.html to calculate your dosages. It is a very handy tool that may seem just a bit daunting at first.
