Thread: Turned pump off after vacuuming and it threw the dirt back into the pool.
    nate81's Avatar
    May 2013
    Raleigh, NC
    190
    So, idk what i've done wrong here, but this was my procedure....
    Held vacuum head under water and held hose to return (while pump was on)...this filled the hose with water....i kept the hose underwater and moved it to the inlet...i vacuumed. I disconnected the vacuum hose and then pulled it out of the pool. I switched the pump off and it threw up all the contents of the basket right back into the pool. Then i tried to turn the pump back on, and there was air in the lines.
    So, what is the proper procedure to prime this pump? This is my third season with this pool and i'm either exhausted from the NC heat already and tired from work, or i'm slowly losing my mind...because I cannot remember how to do it!
    Intex 16'x48" Ultra Frame
    Intex 2,650-Gallon Sand Filter Pump
    Intex Krystal Clear Saltwater Filtration System
    Taylor K-2006
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Re: Turned pump off after vacuuming and it threw the dirt back into the pool.
    I think is self primed, let it run for a couple minutes and will work again in full force, someone tell me if I am wrong
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
