Results 1 to 10 of 10
Thread: Emergency question!,
    May 2015
    Mississauga
    29
    I just did a backwash on my pool as we have had so much rain in the last few days. I have rinsed my sand filter and cleaned out my pump basket. I replaced the water in my pump basket and closed the lid and put the system back on filter. When I do that all I get are air bubbles out of the jets. And the water in the pump basket drains out and doesn't came back. I am worried that I am going to burn the pump. Am I supposed to keep the lid open on the pump basket or close it to prevent all the water from draining Please help!
    11.5K gal, IG vinyl, 3/4 HP Hayward Pump, Hayward sand filter, Hayward Chlorinator (Turned Off), Raypak Heater, Taylor FAS-DPD K2006C T/K
    Jun 2014
    15,040
    Re: Emergency question!,
    Lid stays closed on the pump basket!
    Once primed, you may have a small air bleed valve on your filter, somewhere on your system to "burp" any trapped air. But the pump basket lid stays on tightly when the pump is on.
    May 2015
    Mississauga
    29
    But it takes forever to refill. Is that normal?
    Jun 2014
    15,040
    Typically no unless you opened your system and let a lot of air in for something. If it continues. you may want to stop to prevent overheating your pump until someone who has a filter system like yours can reply with more advice. Sorry, that's not in my ballpark.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    If it is taking a while to prime and start up, you may have a suction side air leak somewhere, unfortunately these can be hard to find. see Pool School - Suction Side Air Leaks
    p.s. you said you had the basket open, did you check and lubricate the o-ring with pool lube or silicone lubricant?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,969
    Check the gasket under the pump strainer lid, and make sure you set the valve back to rinse or filter. You wouldn't be the first to set it to the wrong spot.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,439
    Check to make sure all of your valves coming from the pool are open. (don't ask how I know to look for this
    Kim
    May 2015
    Mississauga
    29
    Thanks for all the responses. I re tightened the screws on the pump basket and it solved the problem. Thank you for the article on side leaks. I feel rather stupid now but I am a newbie learning the ropes.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    As long as the pool is fixed it's all good!
    Jul 2012
    Tallahassee, FL
    30,439
    The only way to learn is to try, do, and ask questions!
    Kim
