Results 1 to 8 of 8
Thread: Help Identifying Pool Make/Model
    Jun 2015
    Southampton, NJ
    5
    I recently purchased a home that came with an above ground pool.
    In speaking with the previous owner, they have no information on the make/model.
    What prompted this was the search for top caps to replace what are currently heavily rusted.
    I've been to a number of local pool supply stores, talked to a couple local "experts", and even contacted Inyo Pools in hopes of identifying the pool make/model based on pictures I've sent them.
    Thus far, no one has any idea what the make/model is.
    Attached are some images I took recently, hopefully someone here can provide some insight!
    It is an all steel pool: steel walls, steel supports, steel rail, steel top caps (tested with a magnet).
    Here's a link to a gallery of the pool images: Pool - Album on Imgur
    Any assistance would be great!
    Jun 2015
    Southampton, NJ
    5
    Re: Help Identifying Pool Make/Model
    Wow guess this is harder than I thought
    Apr 2010
    Cache , Ok 10 miles west of Lawton, OK
    37
    I had the same problem I asked a few weeks ago. I never could find my tops. lucky for me ,mine where plastic so I just got some epoxy and repaired them the worst one went under the ladder so no one see it.
    Good luck on your search
    Retired Army and still serving.
    18X54 round above ground pool
    Sand Filter, 1hp pump
    TF 100 Test Kit
    Rover Jr robot cleaner
    Jun 2015
    Southampton, NJ
    5
    Thanks ropdyke, I actually have a local fabricator that I'm working with to hopefully get some made if I can't locate them anywhere.
    Jun 2015
    Southampton, NJ
    5
    If it helps, here's the measurements of the top cap pieces.
    Jun 2012
    western NY
    1,560
    If it is the rust in the picture that is the "heavily rusted", here is what I would do. find a body shop, metal fab shop, buddy... with a sand blaster and have them cleaned off all paint and rust. Next look up in the yellow pages, or on line for a shop that does powder coating. Give them a call and see what it will take to drop them off and have them coated. If you lived close enough to me (and I had the time) I would sand blast them for you and drop them off at my friends business and have them coated in white the next time they run a line of white. The whole deal probably would run you about $150.00
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Jul 2015
    Nettie, WV
    2
    Looks like one that Sears used to sell 30+ yrs ago
    Looks like one that Sears used to sell 30+ yrs ago. My Neighbor has one like it and we had sanded all of the rust off them (which took days) and spray painted them with rustoleum white paint and that was about 10 or so yrs ago and they still look good (no rust)
    Jun 2015
    Southampton, NJ
    5
    Quote Originally Posted by danpik View Post
    Thanks for the feedback.
    I actually did go to a local metal shop and had the 22 front parts of the top caps I needed made up new. They were able to use one of the caps I had and make the same design. Then I just painted them myself with two coats of primer and two coats of white enamel. Came out looking great. Fabrication cost me $200 and paint was probably around $20-30 or so.
