Thread: Polaris 360 gets stuck
    Jun 2015
    Tulare, CA
    5
    My Polaris 360 gets stuck in the same spot every time. I have replaced the back up valve and the hose is not kinked. The vacuum will make a couple of runs around the pool and once it gets close to where the hose comes out of the pool wall, the vacuum will just sit there until I move it again.
    In-ground pool (plaster), 18' X 30', DE Filter, 2 Speed Pump
    wjr75's Avatar
    Jun 2013
    IL
    836
    Re: Polaris 360 gets stuck
    There is a small screen in the fitting in my 280 where it connects to the wall. Not sure what the 360 has but try cleaning it if you have one.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Jun 2015
    Tulare, CA
    5
    Our PB told us to remove that fitting, so we took it out.
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    Sounds to me like your hose is getting caught on itself near the wall fitting.
    Ours did that on occasion. I ended up adding another swivel connector two feet away from the wall fitting. I have not seen the hose get wrapped around itself since.
    You really should run with that screen in place as well. It keeps the small junk out of small hoses inside the 360. No sense in clogging any of those or the nozzles in the cleaner.
    J.R.
    20K IG gunnite pool
    2HP Hayward single speed pump
    Cartridge filter
    Jun 2015
    Tulare, CA
    5
    Thank you jrs_diesel I will try that.
    Quote Originally Posted by jrs_diesel View Post
