Thread: Cleaning Cooldeck
    Sep 2008
    Jacksonville, FL
    105
    Cleaning Cooldeck
    I am not sure what everyone calls the standard decking around a pool, but we call it cooldeck.
    Anyway, my father has a very light duty electric pressure washer and I was wondering if it is safe to lighlty pressure wash it because there is a ton of inbedded dirt in it.
    Any thoughts, opinions or suggestions on how to clean it would be great!!!
    Thanks everyone!!!
    16,500 Gallon Plaster, Pentair WhisperFlo WF-26 1 1/2 HP Up-Rated Pump, Pentair Clean n Clear 150 Cartridge Filter, BioGuard Mineral Springs MS-10 SWG, Hayward Navigator Cleaner, TF-100 Test Kit, Apollo Magnetic Stirrer
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    Re: Cleaning Cooldeck
    I've used a 1700 psi pressure washer to clean my cool decking and it worked very well. Just don't get real close or it may remove any loose decking material. Also don't use a 0* nozzle, try to stay with a 30* - 40* nozzle.
    My pool is a 10,500 gallon (420 Sq Ft ) kidney shape. STA-RITE HRPB30, Sand filter 30" 98 GPM, 1 HP Maxi-Glas 2 pump, BBB Method, Taylor K-2005 test kit, 50 Watt 12V low-voltage pond light illuminates the pool at night for a nice soft glow.
    Sep 2008
    Jacksonville, FL
    105
    I cleaned the cooldeck this weekend using a low pressure electric pressure washer and it did a great job!!! It was so low of a pressure washer that when it hit my foot a couple of times, it had a slight sting but made me feel safe about how light it was on the cooldeck.
    Just thought I would update everyone.
