Thread: Use IQ20-RS to control Jandy actuator for spa bubbles?
    Apr 2015
    Covina,CA
    22
    I just got an IQ20-RS and it's great being able to use my phone to operate the system. With my old RS4, I had no way of controlling the air supply for the spa jets other than running back to the pool house and removing/placing a cap on the intake pipe. I wonder if I could get a cheap Jandy valve and an actuator and somehow hook it up to the RS aux line to control the air line with my phone too? I do have the J12 (electric heater) jack free as well as aux4-7 available.
    30k gallon pool w/spa. iAqualink IQ20-RS, Jandy All Button +Spa control, Pentair IntelliFloVS plus 1hp spa booster, Kreepy Krauly poolvac.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Use IQ20-RS to control Jandy actuator for spa bubbles?
    Sorry, can't help with this. Here is a
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    This can be done, however, the iQ20 board has only 4 actuator sockets available. You currently are using at least two right now for the pool and spa, or, suction and return actuators. Do you have solar? That would use a socket. A pool cleaner that is run off the pressure of the filter pump? That would take up one too. So you have to make sure that you have an available actuator socket before you can go any further.
    Factory Warranty Station for:
