Thread: Reducing CYA Patent
    Jul 2013
    Long Island, NY
    157
    Reducing CYA Patent
    Found this when doing a search on "reduce CYA pool". Found it interesting if it actually works:
    https://www.google.com/patents/US20130186837
    20x40 in-ground Bella Blue Pebble Fina pool w/diving board, 1 HP Hayward Superpump, Raypak RP2100 335k BTU NG mV heater, Pentair Quad DE 60 filter, Pentair 261173 multi-port valve, Stenner 45MPHP10 pump w/15 gal tank, Intermatic ET1125CR dual electronic timer, 1.5" lines, two skimmers w/socks, Poolskim, vacuum line, ColorQ Pro 7 kit, TF-100 kit, speedstir, 2 froglogs, Dolphin Discovery Robot. Wine is the answer, what was the question?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    Re: Reducing CYA Patent
    Go over to The Deep End forum. We have has several folks try it with less than spectacular results.
    Support the site
    Jul 2013
    Long Island, NY
    157
    Dang...should have done a search here first. Figures you guys are up on all of this already!!
    May 2014
    Franklin, NC
    9,193
    Quote Originally Posted by skimmerswimmer View Post
    We try
    Support the site
    Mar 2007
    San Rafael, CA USA
    12,082
    The patent application you linked to is NOT about the BiOWiSH Bio-Active CYA Reducer product. Instead it is about using melamine to precipitate melamine cyanurate. There used to be a product that used this technique, but it generally created a cloudy mess in the pool because melamine cyanurate is partly soluble so the melamine that hangs around would precipitate with CYA as the CYA rose and have the pool be cloudy. It was also pH dependent where a lower pH would precipitate more. The product is no longer sold, as far as I know.
    This patent application is the one for the BiOWiSH Bio-Active CYA Reducer that has generally poor results.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Yes, the search feature is your friend. Bio-active is the word to search.
