Thread: Lowering Total Alkalinity
    Jun 2015
    Chicago IL
    3
    Post Lowering Total Alkalinity
    I have heard it is very difficult to lower TA. What is the best method?
    38,295
    Re: Lowering Total Alkalinity
    Welcome to TFP!!!
    This is really the only method besides replacing the water with lower TA water:
    Lower Total Alkalinity
    Although generally there is no need to actively do this as TA is one of the least important parameters for keeping a clean pool
    Jun 2015
    Chicago IL
    3
    Smile Re: Lowering Total Alkalinity
    Welcome to TFP!!!
    I heard if it was too high it could damage the liner? Thanks for the help. This site rocks by the way. Embarrassed to admit but this pool thing took me years to get down.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by tde View Post
    If TA is high along with high CH and pH you can get some scaling, but normally the only problem with high TA is rising pH.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,007
    No. Alkalinity itself will not hurt anything. Think about it - you bathe in and drink the same water you use to fill the pool.
    However, high alkalinity can push the pH up very quickly and if you also have a lot of Calcium, you could grow scale. It's like grow-your-own sandpaper on the walls and floors. If you could posts some test results, we can tell you if that should be a concern or not.
