Results 1 to 12 of 12
Thread: CYA/FC chart
    DSdiver's Avatar
    Sep 2013
    South Eastern Wisconsin
    31
    CYA/FC chart
    Which chart should a person use there is 2 of them one older is the new one better? It seems my FC should be higher with the new one. Or is either ok to use?
    20x40 IG vinyl lined 34,100 gallon/Hayward filter EcoStar model SP 3400 VSP/Hayward filter(sand) model S310T2 flow rate 98GPM/RayPack gas heater model 266 266,000BTU/Aqua Plus Automation and chlorination with Hayward Turbo Cell T-Cell-15/Hayward universal color logic light/ Delta UV filter/4 return lines 2 skimmers and dual main drains/Auto cover/ Pool is 3 years old. TFT test kit XL speedstir.
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: CYA/FC chart
    Are you talking about this chart: Pool School - Chlorine / CYA Chart
    One is for a pool without an SWG and one is for a pool with an SWG.
    Mark
    Scuba_Steve's Avatar
    May 2015
    Pooler, GA
    311
    Re: CYA/FC chart
    This one:
    Chlorine/CYA Chart
    6425g Intex Ultraframe 18'x48" AG
    Stock 1500gph cartridge filter / Intex SWG CG-28669 with E.C.O.
    Install date: 5/26/2015
    TF-100
    Helpful Links
    DSdiver's Avatar
    Sep 2013
    31
    Re: CYA/FC chart
    Steve thanks,
    What is the other one about it looks like it requires you to keep your FC higher then the one you posted.
    http://www.troublefreepool.com/threads/2177-Chlorine-CYA-Chart This one is the other I was referring to.
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: CYA/FC chart
    Pool school is a rounded version of Chemgeeks to simplify it.
    Acknowledgment: The original Chlorine/CYA "Best Guess" chart was developed by Ben Powell. Richard Falk (chem geek) has refined and expanded on that original to produce the Chlorine/CYA Chart by Chem Geek based on experiences with members on this forum and the old Pool Forum and conformation to chemical theory.
    Mark
    38,532
    Re: CYA/FC chart
    The one you just posted has more decimal places ... they should round to the simplified one in Pool School.
    I guess I do not see the difference you are talking about.
    DSdiver's Avatar
    Sep 2013
    31
    Re: CYA/FC chart
    Jason,
    So on the pool school chart if you have a CYA of say 80 you MinFC is 4 and the target is 6. Then the other one has a MinFC of 5.8 and a target of 9.1 for a CYA level the same. Look I don't want to be a nut case if the one posted in pool school is good I will stay with that.
    Jun 2014
    15,274
    Re: CYA/FC chart
    I just compared the 2 charts and they appear to coincide. Chemgeek's detailed chart was simply rounded-up or down for the more common chart (non-SWG) we use.
    DSdiver's Avatar
    Sep 2013
    31
    Re: CYA/FC chart
    Ok thanks sorry for the confusion on my part
    Jun 2014
    15,274
    Re: CYA/FC chart
    Perhaps that's where the confusion is ... Non-SWG chart versus the SWG below it.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: CYA/FC chart
    The chart I made has non-SWG values. I refer to SWG values in the later text in terms of a percentage (4.5% of the CYA level) but I don't show a chart for it whereas the Pool School SWG chart rounds to roughly 5% of the CYA level.
    DSdiver's Avatar
    Sep 2013
    31
    Re: CYA/FC chart
    Yes! I see this now. Once again thanks for getting me straight I had never seen the link before and I didn't realize what I was looking at. My pool water has become kind of an obsession and I love to tweak it to all of the recommended levels you guys have so when I got confused I had to ask.
