Thread: Pump Housing Nut Insert Dislodged
    Jun 2015
    Whittier
    2
    Greetings. I'm a newbie here and need some guidance.
    While changing the gaskets on my Hayward Super II pump housing, the bolts were over tightened causing the threaded inserts to dislodge. Mu question is what is the best method to re-insert them and prevent separation & leaking?
    A fellow pool enthusiast suggested using J B Weld (water rated product) but I'm seeking other suggestions and alternative methods to correct this problem.
    Thank in advance for your time and expertise:confused:
    Angel G.-In Ground Kidney Shaped Pool Approx 18,000 gls (Painted) Hayward 48 sq ft DE Filter, Hayward Super II Pump with Multi Port Valve, Hayward Swim Pure Salt System Originally Built in 1980's No Spa/Additional Equipment (Kreepy Krauler Cleaner)
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    Re: Pump Housing Nut Insert Dislodged
    I'm not sure that could be counted on to hold. Very risky at best. what if it comes loose when it's running?....you don't want that.
    if it were me I would buy a new pump housing.
    Dolphin E10 Cleaning Robot.
    Jun 2015
    Whittier
    2
    Thanks borjis for replying, I saerch online for options and found this link Hayward Repair Tap Set, F/pump Housing Wg (sp1600tap) - INYOPools.com
    I appreciate your feedback.
