Thread: Newbie's story and a thank you.
    Hello everyone!
    I have a 12,000-gallon, in-ground SWG pool, with spill over spa, in South Florida. I never really took intensive care of my pool and hence the old marcite finish was greatly deteriorated and a resurface was imperative. Thirty days ago, my friend (an experienced tile man who has done dozens of pools), his son and myself, resurfaced my twenty-year-old pool with ceramic tile and grouted with diamond brite.
    My friend’s technique of tiling around the perimeter, reducing the rows of netted tile as we approached the pool’s floor, yielded a magnificent finish. He told me the tile would shimmer at night with the underwater light on but the hazy water would never clear completely. I would shock the pool and it would clear for a day and then get hazy again. After reading this forum, I learned the BBB method and also the purpose and procedure of shocking.
    I shocked for five days with 10% liquid chlorine from Home Depot.
    Ran the filter 24/7, changing the cartridge once.
    I kept the SWG at 100% output.
    Brushed the walls, floor and skimmed the surface daily.
    Tested water twice daily (AM/PM)
    Compensated for FC loss by adding liquid chlorine.
    Finally achieved no FC change from day to day.
    While shocking, I could not check CC accurately with the K-2005 so I focused on keeping the FC level at 15 using the pool calculator and testing FC by diluting sample as per Taylor’s instructions.
    PH stayed high 7.8 –8.0 throughout shocking but I only added acid once to drop from 8.0 to 7.6
    I also needed to:
    Increase TA from 20 to its current level
    Increase CH from 40 to its current level.
    Increase CYA from 20 to its current level
    Current levels:
    CL – 9.5
    PH – 7.8
    TA – 60
    CH – 120
    CYA – 60-70
    It took about a week to get things in harmony.
    FC has been steady for two days with filter running normal eight-hour cycle and testing before and after the cycle. Today I turned the SWG down to 75% and will monitor the FC level to attain a level of 5-6 ppm. After attaining my target FC, I will adjust the PH to 7.5 if it does not lower on it’s own. My question is regarding CH. I have read the level should be between 200-300 but the diamond brite grout has me puzzled. I was warned by the pool store that if not cured right, it could turn into a ‘peanut butter’ consistency. There are no signs of that now and the diamond brite grout is very firm. Would increasing the CH help me now or should I allow the grout to cure for 90 days and then raise it?
    I now have stored in my garage, a gallon of 10% liquid chlorine, a 20# bag of baking soda and a box of Mule Team Borax. I feel I have the necessary tools on hand to ensure levels may be maintained.
    Next trip to the pool store, I will stock a small bucket of stabilizer as well.
    I have never had cleaner water or a more striking appearance to my pool. The tiled floor truly does sparkle.
    This is a great forum promoting great advice. Your stealth contributions to my success are appreciated.
    Regards,
    -Gary
    Test kit -> K-2005 (awaiting K-2006 kit which should arrive any day).
    SWG -> Auto Pilot Soft Touch
    Hayward Star-Clear Plus Cartridge Filters
    12,000 gallon, tile finish, in-ground pool with spill over spa.
    Pump - Sta-Rite 1.5 HP
    Filter - Hayward Star-Clear C-1200
    SWG - AutoPilot Soft Touch
    Pool Skim
    Zodiac MX8
    BBB since 11/2008
    South Florida
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Newbie's story and a thank you.
    Quote Originally Posted by ge2655
    I just wanted to say welcome!
    I highlighted this portion of your post, as your query was somewhat buried in your o.p., and I didn't want it to get lost. So
    And hopefully a guru who knows more about CH than I do, will be along shortly to advise.
    Good luck, enjoy your newly refurbished and sparkly pool!
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    That's what it's all about!
    I'd love to see some pics of the pool, especially at night if you can swing it.
    As for the calcium, I'd go ahead and increase it to plaster pool levels (~250-300). Your water temperature will make a difference here, so let us know where you are.
    I will comment on your future purchase of stabilizer... with a CYA of 60-70, you don't need much more!!! Most SWG's recommend a level of 60-90, so add it carefully!
    One other thing:
    Welcome to TFP!
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
    A few images of my pool restoration.
    BBB method
    FC - 6.5
    TC - 6.5
    PH - 7.4
    TA - 70
    CH - 210
    CYA - 90
    Pool Skim
    Zodiac MX8
    BBB since 11/2008
    South Florida
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Nicely done!
