Thread: Powerflow Matrix Shaft Seal
    Jun 2015
    Colchester/CT
    1
    I am hoping someone can verify I am looking in the right place. I noticed that the back of my pump (motor end) was running a decent amount of water out of it. So I figured I needed to replace the shaft seal assembly. Being fairly handy, I replaced that with no problem. Now I am getting drips (every second or two) in the middle of the pump. I thought maybe I didn't seat the seal correctly, so I redid it. Same results. I replaced the strainer O-Ring, same result. I have not replaced the housing O-Ring yet, but I guess that is next.
    Could there be something else? Could I have ruined the new ceramic seal when I was pushing it? I am at a loss of what to try next. The leakage is significantly less then before, but the constant drips needs to be fixed.
    Thanks in advance,
    Dominick
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Powerflow Matrix Shaft Seal
    Welcome to TFP!
    Sorry nobody has responded to you. Here is a
