Thread: Adding valve to intake
    Jul 2014
    Warwick/NY
    7
    Question Adding valve to intake
    I want to add simple ball valve to my above ground pool's intake port but not entirely sure how to connect hose to it.
    Intake has female thread where I thread my hose adapter. I'm guessing thread 1.5" diameter although it measures slightly above 1.8". I have bunch of these adapters (see pic) so I'm guessing it's no problem to glue a valve to one of them. Question is how to will I connect my standard filter hose to the valve? Just glue short piece of PVC pipe and attach hose as usual with clamp?20150610_121908.jpg
    27' AG Round (15000 gal)
    Hayward DE
    Mar 2015
    Medina, OH
    17
    Re: Adding valve to intake
    the easiest way would be to just buy a ball valve with the 1.5" threaded end and a normal hose fitting on it, like this
    24ft round AG, ~13k gal. Hayward power-flo matrix 1hp pump.
    Jul 2014
    Warwick/NY
    7
    Thanks!
    Hayward DE
    Cypress, Tx.
    154
    You can also buy a screwed valve and attach a hose barb x screwd end fitting. I buy the threaded fitting so I can reuse them if I reconfigure. Valves and unions are a little pricey and I hate to throw a good one away.
    Intex 18ft dia. Ultraframe, 6500 gal. above ground Intex pool with Hayward C550 cartridge type filter and Intex Krystal Clear Ozone and saltwater system model ZS8110, Taylor K-2006 test Kit, Pool filter supplemented with Duda Diesel 1 micron filter bag
    Located in Cypress, Tx.
    Jul 2014
    Warwick/NY
    7
    You mean something like this?
    Hayward DE
    Cypress, Tx.
    154
    Quote Originally Posted by bratan007 View Post
    That's the animal right there.
    Here is mine installed
