Thread: New Pool owner, older existing pool, need help with Vacuum
    Jun 2015
    Lafayette, LA
    2
    Hi all, we recently purchased a home with an existing pool, about 25k gallons, rectangle in shape, with a single skimmer basket. Pool goes from about 3' to almost 9.5' in the deep end. I originally bought a robot to clean the pool, but with all the leaves and debris from our yard, and neighboring yards, it wasn't doing the job. So, I sold that, and recently bought a Baracuda G3, along with the leaf catcher to put inline.
    Well, all parts come in yesterday, clean out filters, gets going great for a few minutes, then stops. Hose is still shaking, just not as hard as when it first starts out. Shut everything down, cleaned out what little debris was in it, start it back, same thing. I just changed out the pump about a month ago due to the old one dying, seems to have good suction when the basket is in place.
    This is an extremely old pool, I'm guessing 35+ years, so there is only the skimmer basket to use, no booster pump.
    I'm at a loss, can't seem to figure this mess out, and I like to think I'm pretty good with things of this nature.
    Any help would be great
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,638
    Re: New Pool owner, older existing pool, need help with Vacuum
    How does the pressure feel coming out of the return? What does your gauge say? Is the pressure going up?
    That is all I have as I do not have that kind of cleaner. I just wanted to see if this helps.
    Kim
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    In addition to KimKats above:
    - Can you flush the vacuum hose out - something may have gotten lodged in it between the vacuum and leaf catcher?
    - Does the suction at the skimmer feel the same if you pull the hose out as before you started vacuuming?
    You can take boths ends of the hose, pull it over to the return jet then put one end over the jet. All the water should then come out, at a similar rate, of the other end of the hose. Lots of brand new pools only have one skimmer and no booster pump. Even though it is a little old, your setup can work just fine.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Jun 2015
    Lafayette, LA
    2
    Just so happened that the pool company came to do the maintenance on my pool yesterday after I wrote the post. My pressure gauge is reading between the 14-15 mark, and the vacuum seems to be working fine. There may have been some trash in either the lines, or the return, as it is now running pretty good and getting around the pool well. Also I backwashed and rinsed the filter, that may have had some bearing on the performance.
    25,000 Gallon
    In Ground
    Gunite Finish
    Sand Filter/Saltwater
