Thread: Help!! Cloudy Pool!
    Jun 2015
    Oregon, Ohio
    3
    Help!! Cloudy Pool!
    We could not clear up our pool so switched to a sand filter and saltwater system about 5 days ago. The water is blue but very cloudy. cannot see the bottom at all.
    Took a water sample to the pool supply store to get tested. All levels are good.
    Saltwater system levels are all good. No warning lights on.
    Been doing the normal backwashing
    So why is it cloudy if all levels are good? Im getting very frustrated with this pool.
    We do not have well water
    Pool size is 28x52
    We bought the required size sand pump and saltwater system for this size pool.
    I just dont understand it!
    Please help!
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Help!! Cloudy Pool!
    Welcome to TFP! Sorry your pool is cloudy. The pool store told me that my pool was good too. However my water was also blue, but could not see the bottom.
    I followed the SLAM process on here and 13 days later my pool was great!
    You will need to invest in a recommended test kit to follow the SLAM process.
    I will be back with a few links for you.
    Pool School - SLAM - Shock Level And Maintain
    Pool School - Getting Started
    Pool School - Pool Chemistry
    Pool School - Handy Reference
    Read through these pages.
    Feel free to look at My SLAM Process linked in my signature also to se the TFP methods do work.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Skitch's Avatar
    May 2015
    Athens, Georgia
    112
    The first thing every pool owner needs is a good test kit. Pool store testing is notoriously inaccurate. Most of the people here use either a Taylor K-2006 or a TF-100. They are very easy to use and come with step by step instructions.
    You'll need to post the results from your tests to get good advice here in the forum.
    18,400 gallon 28' round above ground pool sand filter 2013 K-2006 2014 new Hayward pump 2018
    My pool turned green the second year, K-2006 saved me, Trouble Free Pool set me free
    Jun 2015
    Oregon, Ohio
    3
    Ok. I did test the PH and Chlorine myself and both read good. I watched him test the water and he did use the drops just like we would and all levels were good.
    I read something on here about bubbles caused by a leak causing the water to look cloudy. Being we have only had this system hooked up for 5 days, is it possible something was not hooked up right or may have a leak somewhere?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,496
    Welcome to TFP!
    We need to see numbers. "Good" doesn't mean a whole lot, as you say, the pool is cloudy so something is not "good".
    The most likely scenario is that there is not enough chlorine in the pool for the CYA level. What number is you chlorine? Do you know what your CYA/Stabilizer number is?
    Here is what we are looking for to be able to help you better.
    Pool School - Read This BEFORE You Post
