Thread: Will this blow my lines apart?
    Jul 2014
    okc
    11
    I have a leak in my suction lines. My skimmers are linked together underground somewhere and then run to a 3 way jandy linking the 2 skimmers, main drain and the pump. All the piping is underground but is not under concrete but a wood deck. All the usual suspects have been investigated and dismissed so I am in search of finding the cracked joint or elbow or whatever it is. I am against a leak detect co because where I am it runs $400 for 30 min for 1 leak and no guarantee that will be the only one. Beyond that additional searches run $300 per.
    My question is If I close my Jandy and plug off one of my skimmer lines and then fill the other with a hose bladder: BrassCraft Small Drain Bladder-BC00331 - The Home Depot
    attached to the spigot will that blow my lines? I'm assuming that I have 30-50 psi at the spigot. I've seen hose bladders used to clear very difficult drain clogs deep below a sink (water pressure builds until the clog fails and releases). If the piping holds I believe I should see the water begin to emerge after some time revealing the leak(s). Anyone tried this?
    1977 Plaster 25K Gal (2014 replaster)
    1HP Pentair 348023 SuperFlo Energy Efficient Single Speed Pool Pump 230V;
    Hayward 48 sqft DE filter
    1.5" suction/return lines
    2 skimmers and 2 inlets
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,982
    Re: Will this blow my lines apart?
    No, it won't damage the plumbing. PVC pipes and fittings are made to withstand normal water pressures.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    No, I don't think you will blow anything apart. Schedule 40 PVC in the sizes used for the suction lines is rated at well north of 200 PSI depending on the exact pipe size (each has it's own rating).
    Support the site
