Results 1 to 8 of 8
Thread: New DIY Pool Build/First Time Pool Owner Getting Ready to Fill
    TW Pool's Avatar
    Mar 2015
    The Woodlands, Texas
    79
    Hello all! I am expecting my plaster crew to show up tomorrow to install my Wet Edge Satin Matrix product and will have acid wash on Thursday and we will begin filling the pool. (My pool build in in another thread.)
    I'm about to be a first time pool owner and have built this pool myself. I just got my TF1000 kit in the mail TODAY, but haven't researched where to start. (I've been busy building the pool and working.) I'm pretty technical, so I expect to follow the logic from the ABC's, but I don't even have any chemicals yet - nor have I read up on using my new test equipment.
    I'd appreciate any advice/pointers for new pool startup and chemistry.
    Thanks and I look forward to much more dialogue!
    New DIY IG pool in Houston, Texas. 4/30 dig to 6/11 fill. 20' x 42.5' free form pool/raised spa with the following equipment: 3hp Intelliflow pump shared between pool/spa, 120gpm Pentair Waterfall pump, 6' sheer decent, 2 bubblers, 2 large color LEDs in the pool/1 small in the spa, Easytouch 8 with ScreenLogic2, Stenner Pump, auto fill, a 2HP silencer pump for the spa, 850 sq. ft Sundeck, Dolphin Supreme M500 and a TF100+mixer
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: New DIY Pool Build/First Time Pool Owner Getting Ready to Fill
    get out that brand new kit and test your fill water and post the results here and so we can see where your at..
    You will need
    30 CYA to begin (you are in tx, maybe 40 to start)
    muriatic acid to keep the PH down and to take TA down
    bleach
    easy peasy
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,410
    Go ahead and test your fill water. That will show you the PH and TA right off the bat. If you are on city water test for FC as you never know.
    It is nice to see someone that already has the test kit! You will NEVER get pool stored!
    Kim
    30,403
    Yep, using the kit right off the bat and then posting your results of the water you will fill with is the first step. You certainly will not need ALL additives until we see the results.
    From those numbers a good dialogue will start. read "The ABC's of Pool Water Chemistry" up in Pool School.....I think you intend to but just a reminder.
    TW Pool's Avatar
    Mar 2015
    79
    Thanks all! First test is in the bag. My tap water reads:
    1.5 FC
    .5-1.0 CC
    2-2.5 TC
    50 CH
    330 TA
    And my black dot never went away on CYA.
    Any thoughts?
    Jul 2013
    Fletcher, OK
    3,353
    what jumps out at me is your TA, its recommended to have a TA of 70-90.. with a TA 330 your PH may rise very fast, it will take muriatic acid to bring down and let the ph rise on its own.. Pool School - Lower Total Alkalinity we will have to see what you PH does
    Jul 2012
    Tallahassee, FL
    30,410
    Did you test PH?
    Your CYA should be 0 in your fill water. That is something you need to buy and add to your pool water. Use pool math to find out how much. You can go ahead and buy it to have on hand to add to your pool when it gets water. Tell us when you are ready to add it and we can tell you the best way to add it.
    Kim
    TW Pool's Avatar
    Mar 2015
    79
    Ok. We completed our fill on 6/12.
    Initial readings on 6/13 were:
    PH 8.2
    FC 0
    CC .5
    TC .5
    CH 50
    TA 310
    CYA 0
    Over the next 2 days, I have added 3 gallons of muriatic acid, 1 gallon of liquid chlorine and about 25# of Calcium Chloride. My new readings were:
    PH 7.2
    FC 0
    CC 0
    TC 0
    CH 225
    TA 180
    I am dropping my PH and TA levels to try and get my pebble cleaner. I plan on keeping the PH low for another 24-48 hours before adding chlorine and walking the PH back up to hop in it. Any thoughts? My girls are dying to jump in!
