Thread: Heater Not Turning Off Properly
    Dec 2014
    Apple Valley, MN
    27
    Hi folks,
    I've got an older built-in tub on my deck. I started working on getting it set up this last weekend. My remaining hurdle is that the heater isn't turning off when the pump turns off. I can turn the heater off with the temp control on the hot tub or on the heater itself, so I don't believe it's the contactor in the heater--it moves freely, too. I've been paying attention, so I haven't let the heater run and trip the high-limit switch.
    Is this likely to be the controller? I've been tossing parts at the tub. Conveniently, I've got an indoor tub that has the same exact equipment. I can swap out parts from the controller, which I suppose will be my next step. So far I've had to replace the heater's circuit breaker and swap out the timers. If this wasn't a very busy time in life, I think I'd actually enjoy the trouble-shooting and repairs.
    PS, I've been very thankful for the advice I've received here, both directly and indirectly. Thank you to all of the contributors who make this site such a great resource!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: Heater Not Turning Off Properly
    There should be some kind of pressure switch so the gas cuts off the instant the pressure drops below some set point.
    Dec 2014
    Apple Valley, MN
    27
    There is a pressure switch, and I bet I have it set way too low. I'll find the heater manual and see what their recommendation is. Thanks! I'll report back tomorrow night.
    Dec 2014
    Apple Valley, MN
    27
    It was the setting on the pressure switch. Thank you for the help!
