Results 1 to 14 of 14
Thread: Just starting with SWG - need help with pool chemistry and start up
    Jun 2011
    Illinois
    22
    Greetings to all!
    I have just installed the AquaTrol SWG on my oval pool. I did not turn it on yet.
    I added salt and now I have the test results from pool store:
    - Salt - 2750 ppm
    - FC - 0.27 ppm
    - CYA - 7 ppm
    - TA - 25 ppm
    - pH - 7.27
    - CH - 220 ppm
    Using the PoolMath calculator, I have added 40 lbs of salt, 7.2 oz of pH+, 161 oz of baking soda, 97 oz of stabilizer.
    What should I do with chlorine? Add bleach (97 oz) or turn SWG on and wait until FC will come up?
    Looks like the new test I should do in one week when the stabilizer will be completely dissolved. Am I right?
    Is it safe to swim in the pool now?
    Thank you very much,
    y51
    12.5K gal, above-ground oval, 1.5 HP Waterway pump, 150 sq ft cartridge filter, Hayward AquaTrol SWG, TF-100 test kit
    umpalumpajay's Avatar
    Dec 2014
    West Hills, CA
    157
    Re: Just starting with SWG - need help with pool chemistry and start up
    add bleach to get it where you want it - you don't want to wait for the SWG to do it. way faster to just dump in what you need. then you can start zero'ing in on the % and time you need to run it. get chlorine in there asap then turn the swg on and monitor your levels. make SURE you get your CYA to the right level to protect your chlorine - but you did that and just haven't retested. Get your own test kit like this site recommends - its SO helpful. if i were you...once you have chlorine in there and everything else looks good....SWIM!
    12000g pool + 1000g spa. Jandy 2.0hp epump + separate Jandy pump for Sheer Descent. Jandy CV Cartridge Filter. Jandy Lxi gas heater. Tropical Breeze PebbleTec. Aqualink. Aquapure SWG. Nature 2. The Pool Cleaner 2x. Taylor K-2005.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    you want to wait 24 hrs for the salt to mix before you fire up the SWG.
    Until the salt is mixed in very well, you are likely to get a low reading on the salt test.
    Recommend also to get yourself your own recommended test kit and test the water yourself. Pool store testing is notoriously horrible, as well as their advice.
    Divin Dave,
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Quote Originally Posted by y51 View Post
    Greetings to all!
    - Salt - 2750 ppm
    - FC - 0.27 ppm
    - CYA - 7 ppm
    - TA - 25 ppm
    - pH - 7.27
    - CH - 220 ppm
    don't add any CYA to your pool without first confirming via one of the two recommended test kits. your CYA number is not right if you got it from a pool store. if they say 7, it could be anywhere from 0 to 100.
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Jun 2011
    Illinois
    22
    Thank you guys for prompt and detailed response.
    I have ordered TF-100 test kit.
    umpalumpajay, I don't understand the part of your advise "you can start zero'ing in on the % and time you need to run it".
    My AquaTrol has the knob called Desired Output with 1 to 100% scale and increment of 10%.
    What setting do I need to use and for how long do I need to run the pump?
    Thanks again,
    y51
    Jun 2011
    Illinois
    22
    Thanks, Dan,
    It's a little bit late - I have added the stabilizer. Now, I will keep my fingers crossed
    Best regards,
    y51
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Thanks again,
    he is talking about figuring out run time and the set output. basically, use chlorine to get to the desired FC, say its 8 (will depend on your CYA). you get it to 8, then you set your pump and set your % on your SWCG. run it for the day, check your FC...if its dropped to 6, then you need to increase either the % output or run time. if your FC increases, then you need to lower the % output or run time.
    I would get your FC up to the level you need with liquid bleach, then set your pump to run 5 hours and set your SWCG to 50% and then see what happens. at first, I would try to keep the run time the same and adjust 5%...but if you get to where you are having to increase the % output to 80-100%, then you should increase run time instead.
    clear as mud?
    basically you want to get your SWCG dialed in so that your FC stays constant every day. takes some tinkering to do that. also, test your FC at the same time everyday. I test mine at the end of the pump run, so I know maximum FC value and that the water is properly mixed up.
    Dan
    Jun 2011
    Illinois
    22
    Thanks Dan,
    Now, it makes sense.
    As you mentioned, I should not go above 80% Output. How low can I go with Output %?
    Best regards,
    y51
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Thanks Dan,
    Best regards,
    you can go all the way to 100%, but you are going to shorten the life of your cell. as far as how low? 0%, haha. really its just a matter of playing around with the output and pump run time. I personally want to minimize the amount of pump run time since I have a single speed pump and trying to keep electric costs down. I wanted to keep my run time around 5 hours and increase the percent production from my cell. its all relative.
    if you run your pool pump at 4 hours at 80% production, its roughly going to be the same as running your pump for 8 hours at 40% production. if you have high electric costs, I think it makes more sense to run the pump a little bit less. if you have a 2 speed or variable speed pump, then it makes more sense to run it longer and then adjust your SWCG lower.
    as long as you get it dialed in to hold your FC steady, you are good to go.
    is your 1.5hp pump a single speed pump?? 1.5hp seems like overkill for your size pool, unless you have fountains, water features, etc.
    Dan
    Jun 2011
    Illinois
    22
    Dan,
    I have two-speed pump. What speed should I use?
    y51
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Always use low speed for filtering and SWG. You only need high speed for vacuuming or other occasional situations where you need higher flow.
    Jun 2011
    Illinois
    22
    Thanks to all for help.
    Today, I have received the TF-100 test kit. It was a fun working with it.
    y51
    DFW, TX
    24,502
    Alright! Give us some numbers!
    Here is a handy article about saltwater pool chemistry.
    Pool School - Water Balance for SWGs
    Jun 2011
    Illinois
    22
    My today's test results:
    Salt - 3200
    FC - 6.5
    CYA - 40 (increased from two days ago 20 ppm), on June 9 I added 126 oz of stabilizer. As I read, it may take a week for stabilizer to show correct level. So I am going to wait a couple more days.
    TA - 120
    pH - 7.5
    CH - 175
    My SWG has 50 % setting @ 6 hrs pump run time. I am going to reduce the run time to 5 hrs to bring CL little lower.
    Do I need to be worry about saturation index? The calculator shows -0.35 with target 0.
    I have a little confusion about difference between recommended ranges given by SWG manufacturer (Hayward) and TPF
    pH - 7.2-7.6 (Hayward) vs. 7.5-7.8 (TFP)
    TA - 80-120 (Hayward) vs. 60-80 (TFP)
    CH - 200-400 (Hayward) vs. 50-300 (TFP)
    For last two parameters, my numbers are OK per Hayward criteria and NOT OK per TFP criteria.
    However, I used the TFP criteria when added all chemicals.
    y51
