Thread: Water Pots are dry
    Water Pots are dry
    I noticed that my Water Pots that use to always have some water in them are dry. When I run them they seem to work fine. They fill up and then are bone dry the next day. They used to always have water in them. Any suggestions?
    20,000 gallon IGP, 50 sqft, infinity edge spa - 8 jets, 3 water pots and 2 bubblers
    SWG - Pentair IC40: Delta UV Filter ES Series; Pentair Quad DE 100 Filter; 1 Pentair Intelliflow VSP VS3050; 1 Pentair Whisperflow for water pots and bubblers; Pentair EasyTouch 4 remote; Pentair Intellibrites LED (white) - 2 in pool and 1 in spa; Pentair Master Temp 400 heater; Pebblesheen Finish
    22,553
    Re: Water Pots are dry
    I'm sorry, but you're going to have to explain 'water pots' to me. I've never heard of anything pool related called a water pot. A picture would help a lot.
    Since this post is in the pumping station, I assume it has something to do with pumps, but don't want to hazard a guess.
    Jul 2013
    Lelystad, The Netherlands
    60
    Do you mean your skimmerbaskets ?
    40000 liter in ground vinyl pool with SWG : http://www.troublefreepool.com/threa...he-Netherlands
    Jun 2014
    15,298
    "Scuppers" perhaps?
