Thread: Lab results,clear water.
    Jonette2's Avatar
    Aug 2013
    Oklahoma
    97
    Hi,
    Just offering up my lab results for critique:
    FC=.5
    CC=.5
    TC= 1
    CYA=20
    Salt=3200
    PH=7.8
    I know I need to raise my CYA and my Chlorine, feel free to let me know how.
    Thanks
    IG Gunite pool. 30,000 gallons. Hayward type sand filter. Circupool SI 45 salt system.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    Re: Lab results,clear water.
    Raising CYA is easy. You just buy some stabilizer, pour it in a hole-less sock and tie it off and set it in the skimmer, or dangle it in front of a return or tie it off on something that floats. The sock in the skimmer is less work.
    To raise the FC fast, get some bleach in there before algae gets a toehold.
    What adds what and how to add it Pool School - Recommended Pool Chemicals
    How to use poolmath to figure quantities. Pool School - PoolMath
    Scuba_Steve's Avatar
    May 2015
    Pooler, GA
    311
    Richard, every time I see that second pic I laugh a little inside. Ever see a product called truck nutz?
    When you say lab tested, what do you mean? If you had to send the water away for analysis I would not trust the FC/CC/TC readings to be accurate. Too much time between sampling and testing. If you meant lab in the pool store, well I dont need to say more... If you have direct access to a local lab though then I assume your readings are good to go!
    6425g Intex Ultraframe 18'x48" AG
    Stock 1500gph cartridge filter / Intex SWG CG-28669 with E.C.O.
    Install date: 5/26/2015
    TF-100
    Helpful Links
