Results 1 to 7 of 7
Thread: Turning off AquaRite Generator at night
    Jun 2015
    Ottawa/Ontario
    339
    Hi all
    I turn my pump off at night, and am wondering if I was to switch the salt generator off as well, whether that would cause any damage? Cheers
    Tom
    90,000litre, IG vinyl, 1/2 HP Tristar pump, Sandfilter, Aquarite T-15 ASG
    20000 gallon, IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
    Mod Squad pooldv's Avatar
    DFW, TX
    24,469
    Re: Turning off AquaRite Generator at night
    Nope, no issues at all, most people have their pump off more than on and the SWG is usually wired to turn off with the pump. The flow sensor in the SWG will turn off the generator anyway.
    Jun 2015
    Ottawa/Ontario
    339
    Awesome - thanks pooldv
    Mar 2014
    Gulf Breeze, Florida
    66
    See the reply I received from Hayward support below: I have a variable speed pump with built-in timer. My concern was that I couldn't integrate it with the pump timer.
    "The Aqua Rite will need to be on it's own timer; it will need to reflect the pump time, because if the Aqua Rite stays hot all the time it will be enabled to still take calculation and end up reading low for salt. "
    So, basically, the SWG will read low salt if left on 24/7 (without water flow).
    Chris Hawkins
    18,000 gallon vinyl Inground. Hayward Goldline Aquarite 40k SWG, Pentair Intelliflo VS pump.
    Polaris 3900 cleaner, Pentair Tagelus sand filter. AquaPro 1300 heat pump. TF-100
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    For safety purposes, your SWG should be wired so that it is never on when the pump is off. If an external timer or control turns power to the pump on and off, the SWG should also be wired to that control. If the pump uses its own on-board timer for switching, a seperate timer should control the SWG and be set to never energize the SWG when the pump is off.
    The flow switch on the SWG is a safety device and should not be used as the primary switching for power to the SWG.
    chiefwej
    Jun 2013
    Southern Ohio
    86
    Sorry if this sounds ignorant: I just manually turn on my 2-speed pump with the toggle switch at the back of the pump. I have no timers, etc. I just purchased the Aquarite. Can I just manually turn on and off the Aquarite using the control panel switch when I do the pump? Or can it not have constant power applied at the terminals even? Thanks
    18x36 Lagoon vinyl IG DIY sport bottom 3.5-5-3.5 18K gal. Hayward Tri-Star 1 1/2 HP 2 Speed, Hayward 27" 350lb. sand filter, Hayward Aquarite w/ T-15, 1 skimmer, 2 returns, 2 step jets, 4 deck jets, 1 waterfall, TF-100
    DFW, TX
    24,469
    Yes, you can manually turn them on. SWGs have flow sensors that shut them off, but if the flow sensor fails to shut it off there could be issues, so it is safest to shut it off.
